Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitech 05S Micro Recv.
Old 12-06-2006, 01:11 PM
Tester 6
Default Hitech 05S Micro Recv.
Mike,
Is the Hitech O5S Micro Recvr. a full range recvr. ?
Tester 6
Old 12-06-2006, 08:41 PM
mglavin
My Feedback: (31)
Default RE: Hitech 05S Micro Recv.
I think not, full range is kind of a loose term IMO. See the page below for the 05S specifications.
http://hitecrcd.com/Receivers/HFS05Ms.htm
Old 12-07-2006, 08:48 AM
Tester 6
Thanks Mike,
The spec. shows (1) mile +, that is more than adequate for an electric ! Going to buy one today.
Tester 6
Old 12-08-2006, 09:21 AM
critterhunter
critterhunter's Avatar
Anybody have any experience with this RX? I'm planning to use it on a camera platform and will be flying it as far as I can see the 48"/36" body and very high. It says it's a full range 1 mile RX but the single conversion worries me. I'll mainly be using an onboard pocket camcorder with no live ground feed but may sometimes plug in a 2watt 2.4ghz video transmitter for live ground video. I'm hoping the RX won't glitch under those conditions. I guess I can always do a VERY long ground range check first.
Old 12-08-2006, 12:38 PM
MikeMayberry
MikeMayberry's Avatar
You're better off with the dual conversion Electron 6 for that application.
http://www.hitecrcd.com/Receivers/electron6.htm
Mike.
