Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
OPTIC 6 /SPECTRUM MODULE
Old 12-12-2006, 12:42 PM
Tester 6
Default OPTIC 6 /SPECTRUM MODULE
Hey,
For the first time on my OPTIC 6 I actually used the Spectras ability to
change Freq. , made sure it was locked in and no QPCM selected.
I changed chnl. 19 to chnl 15. I was setting up model #5 for the first time
and was using a JR 549x (09) chnl. receiver. I selected Shift Pos. for the JR
and plugged in servos. Here is what happened ,Note: Optic 6 is Mode II as
shipped:
1. Lt.Throttle stick runs Elevator
2. Rt. Stick Ail. runs throttle
3. Rt. stick Elev. runs Ail.
4. Lt. Rudder Stick Normal
5. Gear Sw. Normal
Had a Jr. 600 Rec. hooked up at same time and it had same symptoms!
Any idea where I may have goofed?
Old 12-13-2006, 11:53 AM
mglavin
My Feedback: (31)
Default RE: OPTIC 6 /SPECTRUM MODULE
The channel assignments are different for Hitec/Futaba TX's. You'll have to pull the servo plugs and reinsert appropriately I suspect.
Channel 1-aileron
Channel 2-elevator
Channel 3-throttle
Channel 4-rudder
Channel 5-gear
Channel 6-AUX
Old 12-13-2006, 01:22 PM
Tester 6
Thanks Mike,
That makes sense now that i know there are X-mitter differences
between the various manufactuers, this should do it.
Tester 6
