Trainer cord problems Eclipse 7 - Focus 4
I've got a strange problem when I run my Eclipse 7 as master and Focus 4 as student.
The only channel that works in trainer mode is the elevator (channel 2).
Everything works ok from the Eclipse when i release the trainer switch.
I'm running the Eclipse i acro mode with only motor, aileron and elevator. And the Focus 4 should be able to control that model...
Janzzon, since nobody is around for now I'll take a shot. Perhaps if you have not noticed the Hitec cord is directional and possibly you have it plugged in backwards. Note: the plugs on the cord are marked 'master and trainer', just try turning it around.
John
John
