Hitec 5955 servo arm screw size
My Feedback: (51)
NC
It may in other posts, but didnt' see it. What size screw do they Hitec 5955's use to hold the servo arm in place? I need to order some replacements.
Gerry
Gerry
CA
RE: Hitec 5955 servo arm screw size
Hello Gerry,
The size of the screw is 2.6 x 8mm. We do offer these screws in a package that you should be able to get at any hobby shop. The part number is 55802.
My Feedback: (16)
GA
DO NOT let some talk you into using 2.5mm screws.
While they will fit, it will be loose.
Had a guy at our field lost his because of the wrong screw size.
Also use loctite or some type of thread locker.
ORIGINAL: Geistware
Lars
My Feedback: (16)
GA
Please read what I said.
I SAID NOT TO USE 2.5 mm.
Please read closely.
Someone else specified the proper pitch at 2.6mm
ORIGINAL: larshkj
They are NOT 2.5 mm. They are 2.6 mm, and I have used them for 3 years without any problems.
Lars
ORIGINAL: Geistware
Lars
I did read what you wrote.
You replied to my post after I suggested to use a part from Microfasteners. And to my understanding, you clearly told the OP that my suggestion was incorrect.
As to your last post, I really don't understand what you are trying to say...? Pitch at 2.6 mm? The screw is 2.6 mm in diameter. The length is 8 mm.
I think we are misunderstanding each other... []
Lars
Lars
