Question glitches and 6 volts
My Feedback: (23)
ID
I am having some glitching problems on a new flight pack I just bought. I'm putting it in a dpultimate. I have not flown it just in setting up the travels... every once in a while the servo's just go nuts, all control surfaces deflecting up and down drastically. It will do this for about 5 seconds then return to normal. here is what I have done thus far, and hasnt helped yet.
Double checked all wiring and rerouted anything that looked suspect.
Pulled out the regulator and went back to a 4.8 system (I thought maybe the regulator was causing problems) Is a regulator neccessary, this is my first 6.0 volt system so I was just advised on one at my LHS?
I had one of the aileron servo's that was acting weird, you could go to full deflection and it would wave up and down very smoothly about 2mm. I pulled it out put another in and the wave went away.
I still have one aileron servo that has a bit of a tick to it. Usually right after it homes it will deflect up very slightly once, about 1mm. Just a quick tick and then returns to normal.
Any advice would be greatly appreciated.
Scott
Scott
Scott
Scott
Can I also put in a request regarding glitching when using a 6v pack with 5945's. I don't run of a regulator and found serrious glitching. Swapped to a 4.8v pack and no signs of a problem.
