Replacement transmitter switches
I had a minor incident with my TX which led to two switches being broken off of my Eclipse. While I don't use the Channel 7 and FLT MODE switch at present I'd still like to have these switches replaced. Being in Australia, and this my only radio, I'm not keen to send it to either Hitec or their local agent for repairs as this would leave me grounded for weeks.
Where could I source replacement switches (which I can competently solder and fit)? Does Hitec sell these as separate items?
Luckily the switches took the damage rather than the radio (which tests out fine) but it bugs me to use a radio with bits broken on it.
RE: Replacement transmitter switches
ORIGINAL: The Raven I had a minor incident with my TX which led to two switches being broken off of my Eclipse. While I don't use the Channel 7 and FLT MODE switch at present I'd still like to have these switches replaced. Being in Australia, and this my only radio, I'm not keen to send it to either Hitec or their local agent for repairs as this would leave me grounded for weeks. Where could I source replacement switches (which I can competently solder and fit)? Does Hitec sell these as separate items? Luckily the switches took the damage rather than the radio (which tests out fine) but it bugs me to use a radio with bits broken on it.
3 Position Switch (Short Lever)
2 Position Switch (Short Lever)
3 Position Switch (Long Lever)
2 Position Switch (Long Lever - Eclipse)
Eclipse Dual rate Switch
Eclipse Dual Rate Rudder Switch
Eclipse Flight Mode Switch
Eclipse Trainer Switch
Switch for mixing
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
