HS-5625MG Problem
AZ
HS-5625MG Problem
Hello,
I just purchased and installed two HS-5625mg servos for use in my ailerons. One of the has a problem. Occasionally when the controls are moved to neutral from an activated position it pauses for nearly one second and then returns to neutral. Needless to say I won't be flying this plane until this is fixed. What should I do?
Tom Schryer
Tom Schryer
AZ
Found the problem
I called your service department and didn't get much help beyond advice to look at everything bit the servo. That was a little frustrating but after testing the servo on every channel and every scenario I decided to try and use an extension with heavy gauge wire rather than the standard wire extension I had been using and presto the servo works perfectly. It does make sense that the digital servos need the heavy gauge wire to carry the increased information. Anyways I wanted to post this for everyones benefit.
Tom
Tom
Which extensions and Ys?
How can I tell them apart after they are out of the bag? I have extensions and Ys, do the heavy
duty ones look different? I know these digitals
draw more amps and need the heavy ones. Thanks.
Re: Found the problem
Tom
Tom
My recommendation is to re-evaluate your configuration with those servos, if they failed once they can fail again, and the next time your plane may not be on the ground.
Big_Bad_John: I know these digitals draw more amps and need the heavy ones.
HS-625
Current Drain (4.8V): 8.8mA/idle and 400mA no load operating
Current Drain (6.0V): 9.1mA/idle and 500mA no load operating
HS-5625
Current Drain (4.8V): 3mA/idle and 400mA no load operating
Current Drain (6.0V): 3mA/idle and 500mA no load operating
HS-5925
Current Drain (4.8V): 3mA/idle and 190mA no load operating
Current Drain (6.0V): 3mA/idle and 240mA no load operating
wire size
The gauge of wire is larger.
standards or all heavy duty; how can I tell which
I have. Are the heavys bigger that the 5625 servo
leads?
Okay; now what?
Originally posted by MikeMayberry
The wire on the 5645's is 20G.
So, if the wire is the same size as the servo lead
they are standard or heavy duty?
Thanks.
AZ
Hilleja is right!!
Hilleja, I took your advice and continued to test the servo. It took about 10 mins but it failed again. Thank you for saving my favorite plane!!! I will be sending this servo back to Hitec for repair/replacement.
TOm
TOm
