HS-81 servo horn screw size
RE: HS-81 servo horn screw size
ORIGINAL: BobWoodhouse What is the spec/size of a HS-81 servo horn screw? Best, Bob
Hitec Screw Set for Resin Geared Servos
In case you also have HS-81MG, the following may assist.
Hitec Screw Set for Metal Geared Servos #55802 "Metal servo Screw Set (5 x short, 5 x long)".
Standard Servo Screws (Metal Gear Servos) 2.6mm x 6 mm & 8 mm to fit
HS-225MG, HS-525MG, HS-625MG, HS-645MG, HS-705MG, HS-925MG, HS-945MG, HS-5245MG, HS5625MG, HS-5645MG, HS-5745MG, HS-5925MG, HS-5945MG, HS-5955TG, HS-5995TG, HS-5996TG, HS-5997TG, HS-5998TG.
The small screws [Five 2.2 x 5 mm Phillip-head screws] fit the HS-65MG, HS-81MG, HS-85MG, HS-125MG.
NB: Never use loctite. In need if star washer is lost, Liquid Thread Lock may be used sparingly and ensure none remains in contact with plastic parts.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
