HS-5475HS servo-plug problems
Over the last 6 months I’ve purchased eleven Hitec HS-5475HS Digital servos. Of those eleven I found four that the red lead connector was not properly seated in the plug to the point that the little plastic finger engages the connector. This was discovered when I almost crashed my W.M. P-51, I saw one aileron go nuts at run up. Earlier that day it passed the engine running range test. Check those pins and connectors! Other than that, it’s a great servo!
PS
Remember to use only the screw provided for the servo arm, don’t use Loctite, cross thread or start a new lead, and this servo won't let you down.
PS
RE: HS-5475HS servo-plug problems
I've not heard of an issue like that with any of our servos... if you want to send them in we could check them out. Perhaps you could e-mail me a picture mikem @ hitecrcd.com
Mike.
Mike.
All I had to do is push the wire/connector all the way down, lightly push the little finger in and test tug on the wires, problem solved. All installed and working. Just wanted to give you a heads up so that you could pass it on to your Q.C.
