What servos can I use?
AB, CANADA
Sorry, but I am still not 100% sure on this issue. I am trying to update my tx\rx equipment to the Futaba 2.4GHz. There seems to be conflicting answers from what appears to be 2 Hitec reps in the same area concerning Hitec servos and the 2.7V.
http://www.rcuniverse.com/forum/fb.asp?m=7637069
I currently have about 20 planes, foamies to giant scale. Must be near 100 servos, ALL Hitec and obviously not all recently purchased. I will not be changing servos in these current planes. I would like to know for sure if there will be any issues with 2.7v in them without finding out the hard way. Also, for current and future builds: are there any current Hitec servos that will not work?
Lindsay
Lindsay
CA
RE: What servos can I use?
The newer digital servos on the market we have not seen an issue with when used with their system. There were some older digital servos that were effected by their low signal voltage so if you come across any older digital servo that works irratically when plugged into their system, you can send it in and we may be able to change some components to remedy the issue.
