Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Recievers for 75 mhz spetra based Optic/Prism/Eclipse
Old 06-09-2009, 02:48 AM
e-sailpilot86
Default Recievers for 75 mhz spetra based Optic/Prism/Eclipse
I am determined to acquire one of the 3 transmitters above and install a Spectra 75 mhz module in the radio, and use it for surface models. I would like to get some 75 mhz recievers, mixed in both synthesized and crystal based. What recievers can I use, what range in the number of channels useing standard PPM? Do Ineed to send in my airplane recievers to set them to the 75 mhz band for a small fortune every time I want 8 channels? The only synthesized reciever Isee that has the correct number of channels, is on 75 mhz, AND is synthesized is the Sombra Labs SL-8
Old 06-16-2009, 12:41 PM
MikeMayberry
MikeMayberry's Avatar
Default RE: Recievers for 75 mhz spetra based Optic/Prism/Eclipse
The only 7 channel 75mhz receiver Hitec offers is the crystal based HFD-08R0 #23775.
Mike.
