Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Old 08-02-2010, 04:59 AM
  #76
Default RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Thanks AT , can't believe I over looked that step.
Old 08-11-2010, 09:31 PM
  #77
<div class="smallfont">Aurora A9, Spectra Pro &amp; Optima - FAQ &amp; Undocumented Features - Mixes, Setups, Tips.
Content updated and transferred to Post # 81.
This as RCU does not provide for Edit/Update to posts after 5 weeks
(C/F ex posts #2 , #39, #45, #49, #57, #72 &amp; #77.)
Inconvenience caused transferring to new post is regretted.
Alan Tong</div>
Old 08-12-2010, 03:50 PM
  #78
misha034's Avatar
A.T. can you please tell me. All my models are set in normal mode. When I go first time to some place for the first time, I do range test an boot up once in scan mode (to let aurora choose clean frequency) and than again turn to normal mode. that will work with first model.
after that when i want to fly my other model it does not respond to commands until i change it again to scan and than back to normal mode, and of course the first model is after that not working too, and i have to go with this procedure all the time. is there any way for safe use of one setup on several models?
thank you
Old 08-12-2010, 04:10 PM
  #79
ORIGINAL: misha034 A.T. can you please tell me. All my models are set in normal mode. When I go first time to some place for the first time, I do range test an boot up once in scan mode (to let aurora choose clean frequency) and than again turn to normal mode. that will work with first model.
after that when i want to fly my other model it does not respond to commands until i change it again to scan and than back to normal mode, and of course the first model is after that not working too, and i have to go with this procedure all the time. is there any way for safe use of one setup on several models? thank you
Scan Mode Scanlinks to one transceiver only.
When changed back to Normal mode, all other transceivers previously linked in normal mode, will not recognize the newchanged setting. After changing back to normal mode, TX will still be bound to that one RX whilstall other RXmustbe re-linked to the freshly chosen clean frequency setting.
AFHSS - Normal &amp; Scan Modes Explained includes Redundant (Dual) Receivers.
AFHSS - How To Select Optimum Channels - For Your Field
AFHSS - ID-Setup A.K.A, binding or linking &amp; Range Testing Spectra Pro Module &lt;&gt; Optima Receiver
Regards
Alan T.
Alan's Hobby, Model &amp; RC FAQ Web Links
Old 08-12-2010, 04:38 PM
  #80
misha034's Avatar
Thank you A.T. for fast response. I think that I will set it all to Normal mode, and forget Scan mode.
Old 09-15-2010, 03:57 PM
  #81
Aurora A9, Spectra Pro &amp; Optima - FAQ &amp; Undocumented Features - Mixes, Setups, Tips.</p>
Content updated and transferred to Post #89
(C/F ex posts #2 , #39, #45, #49, #57, #72, #77 &amp; #81.)
Alan Tong
</p>
Old 09-23-2010, 07:01 PM
  #82
I could sure use a little help. I am trying to setup an ultimate with 4 servos in the wings. I tried to follow Mike's instructions and it worked fine. Then I was going to do duel rates and can only get the bottom wings to respond to duel rates. I am probably over looking something simple but I can't seem to find out what it is.
Thanks Paul
Old 09-23-2010, 07:43 PM
  #83
My Feedback: (198)
Bob Pastorello's Avatar
Just assign all channels in your wings to AILERON....you still have full EPA, Subtrim, Expo affects all servos at once, and Expo does too.
Lets say J3 is AILERON....simply assign the other channels to J3....trim will master into all servos. Very easy and works perfectly.
No mixes, no switches.
Old 09-23-2010, 08:02 PM
  #84
Thanks Bob I will give it a try.....sure miss your old web site
Paul
Old 09-23-2010, 08:52 PM
  #85
Bob if your still here, I have selected a two aileron wing then added two more ailerons. They are all J1 all work fine except when trying to do duel rares and probably expo. I am pluged into chan 1 - 5 - 7 - and 8. From what I gather I am not sure it matters which aileron is plugged into which channel. Anyway the DR don't seem to get passed on to two of the ailerons.
Thanks for any suggestions
Paul
Old 09-24-2010, 12:48 PM
  #86
Thanks for the help I got it figured out.
Paul
Old 10-16-2010, 11:08 AM
  #87
hi, i used the servo speed fun. to lower my flaps slow, but the elavator comp. lower fast . how can i get them to move the same speed only when i used the flaps?
thanks
jesus escobar
Old 10-17-2010, 08:52 PM
  #88
ORIGINAL: fly3789 hi, i used the servo speed fun. to lower my flaps slow, but the elavator comp. lower fast . how can i get them to move the same speed only when i used the flaps? thanks jesus escobar
This thread is intended for answers to questions posted in many various forums.
Please post questions relating tonew topicsas a newthread at
<u><font color="#00265e">Hitec/MultiPlex Radios- Ask Hitec Customer Service</font></u> ,
Thisensures new questions will stand out and be seen and readby all qualified persons.
Alan T.
Old 10-17-2010, 08:54 PM
  #89
</div><div class="smallfont">Content has been updated and transferred to Post # 99
Alan Tong</div>
Old 10-20-2010, 02:25 PM
  #90
<div class="smallfont">HTS- Voice Announcing System &amp; USB Telemetry
<div id="post_message_16338802">HTS-Voice Telemetry Voice Announcing System
HTS-Navi AFHSS 2.4GHz USB Telemetry Receiver
<font color="#22229c">Official announcement for these and many more new items at the IHobby show in Chicago this weekend</font> - an interesting thread....
Aurora A9, Spectra Pro &amp; Optima - FAQ &amp; Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
<font color="#22229c">Alan's Hobby, Model &amp; RC FAQ Web Links</font></div></div>
Old 10-28-2010, 04:29 PM
  #91
My Feedback: (26)
ORIGINAL: A.T.
<div class=''smallfont''>Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.</div><hr size=''1'' style=''background-color: #a7a7a7; color: #a7a7a7'' /><div id=''post_message_13573363''>Links to tips, shortcuts, undocumented features, mixes etc. Basically anything that will help Aurora users maximise the use/programming of their radio. Please start a new thread for any questions, programming, set up or features and the answer can be listed here as a simple link. (Content of this list is regularly updated, as is individual link content, with new information as Q&A arise.)
http://<font color=''#22229c''><u>Hi...10 </u></font>- <font color=''#000000''>2.4GHz</font> and Telemetry detail
http://<font color=''#22229c''>Hitec...ration </font>Video #1 = Normal Mode, Video #2 = Scan Mode.
http://<font color=''#22229c''>Hitec...eration</font> -Video #3 (Answers to questions raised in above Videos 1 & 2., post #2933 page 296 also refers.)
http://<font color=''#22229c''>Auror...deo</b></font> - 7 video Walkthrough of Set Ups - Dashboard, Heli, Glider, Acro etc.
http://<font color=''#22229c''>Auror...deo</b></font> - Basic Set Up <font size=''1''>- new 17Aug10 36mb 7min8sec.
<span style=''font-size: x-small''>Aurora 9ch - Video - Helicopter Set Up - Finless Bob's Review Tips and how-To Series
</span></font>
http://<font color=''#22229c''>Auror... Review</font> RC Groups - By Mike Llewellyn - <font size=''1''>with Video of Screens and Custom Folder setup</font>
http://<font color=''#22229c''>Auror... Review</font> Fly RC Product - by Scott Stoops with Bob Aberle & Thayer Syme
http://<font color=''#22229c''>Auror...cleaner</font> <font size=''1''>is included Aurora package</font>
http://<font color=''#22229c''>Auror...n Issue</font> - 7yr old Justin Jee -<font size=''1''> XFC 2010 RC Heli Competition Flight & comment -</font> videos
http://<font color=''#22229c''>Auror...n Issue</font> - Joe Manor's Dynamic60 doing 333 mph! <font size=''1''>New World 60'' DS Record - </font>Video <a target=''_blank'' href=''http://www.rcgroups.com/forums/showpost.php?p=15545234&postcount=177''><font color=''#22229c''>
Aurora A9 - Latency and Expo Demo </font></a>- Brandon Chitty's 35% Extra set up for giant scale. Video.
http://<font color=''#22229c''>Auror...Latency</font> - Speed Test. Test your own speed and disprove marketing hype.
http://<font color=''#22229c''><u>Au...ual</u></font> (8MB .pdf) search not included. <font size=''1''>(Manual written V1.03, new pages/addendums below)</font>
http://<font color=''#22229c''><u>Au...ual</u></font> (14MB .pdf) search included. <font size=''1''>(Manual written V1.03, new pages/addendums below)</font>.
http://<font color=''#22229c''><u>Au....06</u></font> - New Page for Manual. <font size=''1''>(Includes Butterfly / Crow Set Up)</font>
http://<font color=''#22229c''><u>Au....07</u></font> - New Pages for Manual (x2).
http://<font color=''#22229c''><u>Hi...ual</u></font>
http://<font color=''#22229c''><u>Au...ty </u></font>Hitec Spectra, standard and other brand modules are not compatible. <font size=''1''>Details and pictures.</font>
http://<font color=''#22229c''><u>Au...rap</u></font><font size=''1''> ''#55843 Transmitter Weight Balancer''. Provides best Neck Strap Balance position for Hitec 2.4Ghz Transmitters - available May 2010 </font>
http://<font color=''#22229c''><u>Au...-up</u></font>
http://<font color=''#22229c''><u>Au...ory</u></font> from Eclipse 7, Optic 6, Flash 4&5 and others
http://<font color=''#22229c''><u>Au...e. </u></font>
http://<font color=''#22229c''><u>Au...ed.</u></font> Charge before first use so as not to damage battery. <font size=''1''>Battery is 1300 mAh_charge rate is 80 mAh (to minimise damage if left on to long at any time) = 19-20 hours for first full charge - please read the further details.</font>
http://<font color=''#22229c''><u>Au...ory</u></font> is part #54128 ''TX NiMH battery (6 cell) Pack (Flat Type) for AUR (RA9) 7.2v / 1300 MAh''(not an Eneloop 2000)...... <font size=''1''>NB: see note re fitting alternate batteries.</font>
http://<font color=''#22229c''><u>Au...ent</u></font> Fit Lipol battery and connectors.
http://<font color=''#22229c''><u>Au...ery</u></font> - 2S Lipo Voltage Capabilities.
http://<font color=''#22229c''><u>Au...own</u></font> = <font color=''#ff0000''>TURNS TX OFF </font>to save damage to Lipo Battery and/or TX
(Audible Battery Warning is still at 6.9V with Lipo which provides say 10-20 min before shutdown.)
http://<font color=''#22229c''><u>Au...rms</u></font> Battery types, voltage levels and consumption - with Power/Battery Management Screen Shots. <font color=''#ff0000''>CAUTION - Leave Auto Power Off as ''Never'' when using Lipo Battery. ''Auto Power Off'' is Hibernation Mode only (as with laptops). <font size=''1''>TX Does Not Switch Completely OFF</font></font><font size=''1''> and batteries will be completely drained if TX switch is not manually moved to the off position in good time. Will read as 'Auto Hibernation mode' from V1.06. As with all similar items, Hitec RCD recommend battery be removed and stored separately if TX is to be stored or unused for a period.</font>
http://<font color=''#22229c''><u>Au...een</u></font> SPC voltage has preference over BEC voltage if using tap.
http://<font color=''#22229c''><u>Au...ger</u></font> Charge Plug/adaptor sizes. [<font color=''#ff0000''>Red</font> LED does not change to <font color=''#008000''>Green </font>simply dims out but charge continues same rate].
http://<font color=''#22229c''><u>Au...uit</u></font> <font color=''#ff0000''>Never Jump TX Charge Circuit Diode - Hitec FAQ.</font>
http://<font color=''#22229c''><u>Au...ng.</u></font> includes Field / Fast Charge Aurora, Eclipse 7, Flash 4&5, Laser, Optic 6, Prism 7 etc.
http://<font color=''#22229c''><u>Au...mer</u></font> Set On/Off % of Throttle Stick Movement <font size=''1''>and different reset procedures for V1.04
http://<span style=''font-size: x-sm...</font></span><span style=''font-size: x-small''> problem? TX Auto Saves (flash) Each Session's Programming and Trim Settings etc on Shutdown.</span> <font size=''1''>Allow time to complete task before switching on again. </font>
</font>http://<font color=''#22229c''>Auror...;'.</font><font size=''1''> ''C'' is combined so if you want the same setting in different flight condition use it... ''S'' is for single so as to make the setting unique to the condition ( refer ''Acro Menu'' Video - 8 min 39 sec) T.App is Trim Apply - activate this if trims are to be the same in all conditions. NB activate at start not part way/end of program or other conditions will be out of sync.</font>
http://<font color=''#22229c''><u>Au...ACC</u></font> - OST = Servo Offset. ACC = Acceleration <font size=''1''>(for asymmetrical servo travel)</font>
http://<font color=''#22229c''><u>Au...ion</u></font> In depth explanation
<font color=''#22229c''><u>Aurora A9 </u></font>- Replace Switches with Push Buttons <font size=''1''>pictorial.</font>
http://<font color=''#22229c''><u>Au...een</u></font> Polarised Filter. View at <font color=''#000000''>angle</font> when using Polaroid type sunglasses in bright sunlight .
http://<font color=''#22229c''><u>Au...ock</u></font> - Included upgrade from V1.05 to V1.06
http://<font color=''#22229c''><u>Au...ors</u></font> - Included as an example, due to requests, there may be other suppliers.
http://<font color=''#22229c''><u>Au...vos</u></font> - Use Any Modern Servo with 1.5ms Neutral Position.
http://<font color=''#22229c''><u>Au...os </u></font>- Speed Adjustment, Control Movement Monitor & Servo Auto Test.
http://<font color=''#22229c''><u>Au...er </u></font>DIY Centre Detente (Notch) Slider for <font size=''1''>(Aurora pre Mar10). </font>Center/Beep out of synch with Detent <font size=''1''>Aurora post Mar2010.
</font>
http://<font color=''#22229c''><u>Au...ess</u></font> Throttle <font size=''1''>- negate possible mid range jump. </font>
http://<font color=''#22229c''><u>Au...ing</u></font> to be included in a future Firmware Update.
http://<font color=''#22229c''><u>Au...yro</u></font> Set-up - How to interpret numbers & modes on screen.
http://<font color=''#22229c''><u>Au...yro</u></font> Heading Hold etc set up 450 Heli - a.
http://<font color=''#22229c''><u>Au...yro</u></font> set up 450 Heli - b.
http://<font color=''#22229c''><u>Au...ons</u></font> - Explanation, Use and order of Priority - Video x 2.
http://<font color=''#22229c''><u>Au...row</u></font> procedure updated V1.06.
http://<font color=''#22229c''><u>Au...ow </u></font>Switch/Slider assignment - <font size=''1''>includes V1.05 and V1.06 downloadable files.</font>
http://<font color=''#22229c''><u>Au... up</u></font> EPA, D/R & EXP w/photos
http://<font color=''#22229c''><u>Au...DLG</u></font> Set up guide with many screen shots for setting Camber, P.Mixes, Flap Control etc ***
http://<font color=''#22229c''><u>Au...r )</u></font> - Set Up.
http://<font color=''#22229c''><u>Au...nts</u></font> Posts 226 & 248.
http://<font color=''#22229c''><u>Au...ron</u></font> - Flaps - Set up.
http://<font color=''#22229c''><u>Au...Mix</u></font> <font size=''1''>see also sailplane below
</font><span style=''font-size: x-small''>http://<font color=''#22229c''><u>Au...aps</u></font> - Snap.</span>
http://<font color=''#22229c''><u>Au...ipe</u></font> - Set Up independent Aileron Servos.
http://<font color=''#22229c''><u>Au...Mix</u></font> Tips: 6,7,8 use 7 point curves where 1-5 are linear.
http://<font color=''#22229c''><u>Au...Mix</u></font> In Flight Trimming
http://<font color=''#22229c''><u>Au...der</u></font> - Electric Power Setup <font size=''1''>(inc motor_flaps on/off at low throttle)</font> many screen shots.
http://<font color=''#22229c''><u>Au...ing</u></font> - assign flap channel to a 3 position switch First <font size=''1''>(refer posts 208,209 & 210).</font>
http://<font color=''#22229c''><u>Au...low</u></font> - Video of Heli Tri gear set up. <font size=''1''>(NB use analogue or digital servo as retract servos are 180* On/Off only and cannot be slowed)</font>post #5121. - Retract Curves post #5706.
http://<font color=''#22229c''><u>Au...aps</u></font> Set up with Various Flight Conditions - posts #2052 & #2054.
http://<font color=''#22229c''><u>Au...ode</u></font> - is inhibited if Throttle Lock On.
http://<font color=''#22229c''><u>Au...se.</u></font> -<font size=''1''> How to use Icon and/or Switch method (operates when in transmit mode only)</font>
http://<font color=''#22229c''><u>Au...own</u></font> Set-Up
http://<font color=''#22229c''><u>Au...xpo</u></font> Set-Up. <font size=''1''>[NB: Hitec TX use Minus (-) Expo wherever JR/Spektrum use Plus (+) Expo]</font>
http://<font color=''#22229c''><u>Au...ff </u></font><font size=''1''>post #2239</font>
http://<font color=''#22229c''><u>Au...ght</u></font>
http://<font color=''#22229c''><u>Au... a)</u></font> - Video PMix Tutorial (from text ''how to'' post #2104)
http://<font color=''#22229c''><u>Au... b)</u></font> with own 7-point curve. <font size=''1''>Assigned a two position switch with identical curve on throttle-1 & zeroed out the curve on throttle-2 one position to turn the pump off. posts #1698 & #1699</font>
http://<font color=''#22229c''><u>Au...tep</u></font> Adjustable 1-200 with 12 default (Approx.0.025deg ~ 5deg / Step) - Effect.
http://<font color=''#22229c''><u>Au... up</u></font> Brandon Chitty's 42% Aeroworks Yak - Video presentation of set up.
http://<font color=''#22229c''><u>Au...mo </u></font>- Brandon Chitty's 35% Extra set up for giant scale. Video.
http://<font color=''#22229c''><u>Au...#20</u></font> - VIDEO - Snap to Hover <font size=''1''>(5 min 36 sec) + J.Yee & Basic set up videos </font>
http://<font color=''#22229c''><u>AF...ned</u></font> includes Redundant (Dual) Receivers.
http://<font color=''#22229c''><u>AF...els</u></font> - For Your Field
http://<font color=''#22229c''><u>AF...ing</u></font> Spectra Pro Module <> Optima Receiver
http://<font color=''#22229c''><u>AF...ngs</u></font>
http://<font color=''#22229c''><u>AF...own</u></font> - Procedure for Normal Mode & Scan Mode for Range Check.
http://<font color=''#22229c''>AFHSS... is 1mw</font> - tested to at least 1/4 mile.
http://<font color=''#22229c''><u>LE...ard</u></font> <font size=''1''>- What the colours/combinations are indicating.
. Digital .pdf copy which can be printed and inserted as a page in manual or extra cards made.
</font>
http://<font color=''#22229c''><u>Hi...ual</u></font> .pdf
http://<font color=''#22229c''><u>Hi...are</u></font> for HPP-21 & HPP-21+ for Digital Servos.
http://<font color=''#22229c''><u>Hi...ion</u></font> for HPP-22- Enables update to Aurora, Optic Sport, Spectra Pro Modules and Optima Transceivers.
http://<font color=''#22229c''><u>HF...21+</u></font> - Manuals <font size=''1''>(.pdf bottom each page)</font>
http://<font color=''#22229c''><u>Hi...mer</u></font> - Manual, FAQ - How to install & Use Instructions <font size=''1''>(with screenshots)</font>.
http://<font color=''#22229c''><u>Au...tes</u></font> - <span style=''font-size: smaller''>Program Templates.</span> <font size=''1''>(If you have an HPP-22, download these files and transfer them into your Aurora. Save and share your own set ups. This way you could have more than one set of eyes look at your set up and possibly come up with other solutions). </font>
http://<font color=''#22229c''><u>Au...et </u></font><font size=''1''>- Put all your model settings into a printable spreadsheet.
</font>
http://<font color=''#22229c''><u>Au...ad </u></font>
http://<font color=''#22229c''><u>Au....06</u></font> Details.
http://<font color=''#22229c''><u>Au....07</u></font> & Spectra Pro V2.0 - Effective 13Jul10.
http://<font color=''#22229c''><u>Au....07</u></font> Details, Observations, FAQ & Video update 14Jul10.
http://<font color=''#22229c''><u>Au....04</u></font> - 01Oct10.<font size=''1''> (inc PDF update enhancements, inc set failsafe via HPP-22 & how uninstall V1.03 before new install.)</font>
Optima 7 & 9 - Firmware update V1.02 available, requires an HPP-22, from 23Jun2010
http://<font color=''#22229c''><u>Op...RX)</u></font> - Installation RX, BODA Antenna & Range Test Results. <font size=''1''>{Regularily Updated with Q&A}</font>
http://<font color=''#22229c''><u>Op...est</u></font> ''<span style=''font-size: smaller''> The Hitec system worked as well as any I have tested and better than most. It performed better than the Futaba FASST, the Airtronics, the XPS and the JR low end receivers. It performed at least as good as my reference receiver, the JR AR7000.''
</span>http://<font color=''#22229c''><u>Ca...ort</u></font> - from well known Glider Pilot and Fly RC author Mike Lee
http://<font color=''#22229c''><u>Ca...ort</u></font> - High Speed DS
http://<font color=''#22229c''><u>Op...ned</u></font> - as good, arguably better than a two antenna system.
http://<font color=''#22229c''><u>BO...Tip</u></font> - If a concern, secure with dab ''Shoe Goo'' or Heatshrink tube. (Receivers pre Apr10.)
http://<font color=''#22229c''><u>Op...try</u></font> Includes Battery Voltage Level but not ''Range Out warning''.
http://<font color=''#22229c''><u>Op...ll </u></font>- Low Battery Warning <font size=''1''>not adjustable V1.04<06. Setting Voltage Alerts V1.07. <font color=''#ff0000''>Warning regarding use of Eneloop & A123 2S as RX batteries.</font></font>
<span style=''font-size: x-small''>http://<font color=''#22229c''><u>Op... #1</u></font> <font size=''1''>caution re NiMH.</font>
http://<font color=''#22229c''><u>Op... #2</u></font> <font size=''1''>caution re NiMH.</font></span>
http://<font color=''#22229c''><u>Op...ons</u></font>
http://<font color=''#22229c''><u>Op...SPC</u></font> - SPC connection & Lead Detailed plus Optima Current Draw/Amps<font size=''1''> - NB: View warning Video re use of balance taps.</font>
http://<font color=''#22229c''>Optim... Weight</font> Minima 6E & 6T Receivers plus Caseless Weights for 6 & 7ch Optima.
http://<font color=''#22229c''><u>Op...rs </u></font><font size=''1''>pending release of Minima 2.4GHz series. Hitec ''Factory Pilot'' Brandon Chitty uses the Optima 7 in his indoor competition aircraft (Fancy Foam Maxima) that weighs 8oz, as well as his 170CC DA powered 42% Aeroworks Yak. </font>
http://<font color=''#22229c''><u>Op...led</u></font> Dual batteries for redundancy or even one for each servo.
http://<font color=''#22229c''><u>Op...ual</u></font> -Rebind. <font size=''1''>Switched between Normal <> Scan mode with power off before process completed. </font>
http://<font color=''#22229c''><u>Op... On</u></font> Reason & Prevention of Servo Wag <font size=''1''>(especially when switching on some ESC) </font>.
http://<font color=''#22229c''><u>Op...ing</u></font> - <font color=''#000000''>Battery pack</font> (power supply) failing under load.
http://<font color=''#22229c''><u>Sp...val</u></font> Specifications and Test Results.
http://<font color=''#22229c''>Spect...na Mast</font> Fitting <font size=''1''>2.4Ghz mast to other than Aurora TX as well as DIY mounts for single or multiple (Std & 2.4) antenna to other TX.</font>
http://<font color=''#22229c''><u>Sp...X. </u></font>This if not intending to ever use 72Mhz or other modules.
http://<font color=''#22229c''><u>Sp...m 7</u></font><font size=''1''> not 7X </font>requires minor fix.
http://<font color=''#22229c''><u>Sp...ule</u></font> Delayed until after mid November 2010.
http://<font color=''#22229c''><u>Sp...24 </u></font>- not for use with Optima RX / aircraft
http://<font color=''#22229c''><u>Sp...ual</u></font> - for Surface use only.
http://<font color=''#22229c''><u>Sp...ule</u></font> - JR - 2.4Ghz AFHSS module for JR transmitters. <font size=''1''>- update Jun10.</font>
http://<font color=''#22229c''><u>Mu...HSS</u></font>
http://<font color=''#22229c''>Telem...Sheets </font>& User Guide.
http://<font color=''#22229c''>Telem...Models </font>
http://<font color=''#22229c''>Telem...g Range</font>
http://<font color=''#22229c''>Telem...lemetry</font> Voice Announcing System
http://<font color=''#22229c''>Telem...TS-Navi</font> AFHSS 2.4GHz USB Telemetry Receiver
http://<font color=''#22229c''>Telem...ge test</font> Using Segway & GPS - Video <font size=''1''>- Remarkable 2100+ft not only through large obstacles but also with Heli sitting in ground effect.</font>
http://<font color=''#22229c''>Telem...isplays</font>
<font color=''#22229c''>Telemetry </font>- Full installation in Skylink 50cc - Video( 6 min 29 sec)
http://<font color=''#22229c''>Telem...isplays</font> - Video
http://<font color=''#22229c''>Telem...ad Demo</font> 2D Graphic Flight displays of an actual flight. <font size=''1''>NB: GPS updates every .5 sec and will be fairly accurate for level flight but not dive speed since it is using ground coordinates for the calculation.</font>
http://<font color=''#22229c''>Telem... Source</font> - status
http://<font color=''#22229c''>Telem...nate TX</font> Connections.
Special Offers from Hitec USA. <span style=''font-size: smaller''>These offers are only available to Hitec customers in the USA, Canada & Mexico
</span>http://<font color=''#22229c''><u>Co...ons</u></font>
http://<font color=''#22229c''><u>Fr...-PC</u></font>, subject to valid application, with Aurora 9 bought between October first and December 31, 2010. <font size=''1''>(advert ''Fly RC'' magazine for December 2010 also refers.)</font><span style=''font-size: smaller''>
</span>
http://<font color=''#22229c''><u>Hi...ins</u></font>
http://<u><font color=''#00265e''>Te...ube</font></u>
http://<font color=''#22229c''>Hitec...roducts</font> Ihobby Oct 2010 - Display Photos
Regards
Alan Tong (Hitec NZ).
http://<font color=''#22229c''><u>Al...nks</u></font>
</div>
Alan, I have an A9, and Optima 7 (Ver. 1.07, and 2.0 firmware) respectively. How can I see the airborne voltage on my Xmitter? Also, concerning the 2nd battery pack for the servos, do I simply plug it in the the SPC slot on the receiver, or somewhere else?
Old 10-28-2010, 05:06 PM
  #92
ORIGINAL: Prop_Washer2 Alan, I have an A9, and Optima 7 (Ver. 1.07, and 2.0 firmware) respectively. How can I see the airborne voltage on my Xmitter? Also, concerning the 2nd battery pack for the servos, do I simply plug it in the the SPC slot on the receiver, or somewhere else?
<font color="#22229c">Telemetry - Battery Voltage via SPC for EP Models </font> - see picture,airborne voltage is accessed via the RX battery icon on Aurora's screen which appears only after Aurora On then RXturned On and link complete.
Optima Transceiver (RX) - SPC - SPC connection &amp; Lead Detailed plus Optima Current Draw/Amps<font size="1">
</font>Optima Transceiver (RX) - Battery set up for Nitro/Gas models #1 <font size="1">caution re NiMH.</font>
Optima Transceiver (RX) - Battery set up for Nitro/Gas models #2 <font size="1">caution re NiMH.</font>
Optima Transceiver (RX) - Multiple Batteries may be installed Dual batteries for redundancy or even one for each servo. NB: note detail regarding the use of two packs with one is plugged into SPCand one into servo bus, power to servos is still from the one battery pack only as no power is shared between the SPCport andServo bus.
regards
Alan T.
Old 10-28-2010, 10:32 PM
  #93
My Feedback: (26)
ORIGINAL: A.T.
http://<font color=''#22229c''>Telem...Models </font> - see picture, airborne voltage is accessed via the RX battery icon on Aurora's screen which appears only after Aurora On then RX turned On and link complete.
Optima Transceiver (RX) - SPC - SPC connection & Lead Detailed plus Optima Current Draw/Amps<font size=''1''>
</font>http://Optima Transceiver (RX) - Bat.../Gas models #1 <font size=''1''>caution re NiMH.</font>
http://Optima Transceiver (RX) - Bat.../Gas models #2 <font size=''1''>caution re NiMH.</font>
http://Optima Transceiver (RX) - Mul...y be installed Dual batteries for redundancy or even one for each servo. NB: note detail regarding the use of two packs with one is plugged into SPC and one into servo bus, power to servos is still from the one battery pack only as no power is shared between the SPC port and Servo bus.
regards
Alan T.
I just have a 6 volt NiMh pack as a second pack with a Hitec connector on it. Do I still need the SPC cable or just plug it in, the manual is not too clear...Thanks Alan...
Old 10-28-2010, 11:35 PM
  #94
ORIGINAL: Prop_Washer2 I just have a 6 volt NiMh pack as a second pack with a Hitec connector on it. Do I still need the SPC cable or just plug it in, the manual is not too clear...Thanks Alan...
Negative. Whilst a battery may be plugged directinto the SPC socket<span style="font-size: smaller">or use a short extension lead as a "plug", </span>recommend aswitch lead be used, preferably heavy duty (anti vibration) such as
54407S Hitec Swicth Harness HD JR/Airtronics if for GP or Heli.
Reminder, any battery plugged onlyinto SPC port powersthe receiver and provides no power/backup to the servos nor telemetry of what is happening on the servo power bus.
regards
Alan T.
Old 10-29-2010, 10:36 AM
  #95
My Feedback: (26)
ORIGINAL: A.T.
Negative. Whilst a battery may be plugged direct into the SPC socket <span style=''font-size: smaller''>or use a short extension lead as a ''plug'', </span>recommend a switch lead be used, preferably heavy duty (anti vibration) such as
Reminder, any battery plugged only into SPC port powers the receiver and provides no power/backup to the servos nor telemetry of what is happening on the servo power bus.
regards
Alan T.
Thanks Alan, I think I got it. I have a 5-cell NiMh plugged through a switch to BATT input of the Receiver, and I can isolate the current draw of the servos and assign that current draw to an 2nd 5 cell NiMh pack connected to the SPC port through a second switch...
Am I close..??
Old 11-15-2010, 08:55 AM
  #96
Guys,
Is there a way to back up your model programming on your Aurora 9 to your PC?
Thanks!
Old 11-15-2010, 12:49 PM
  #97
ORIGINAL: PeteS Guys, Is there a way to back up your model programming on your Aurora 9 to your PC? Thanks!
Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to install &amp; Use Instructions <font size="1">(with screenshots)</font>.
Alan T.
Old 11-16-2010, 07:53 PM
  #98
ORIGINAL: A.T.
Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to install & Use Instructions <font size=''1''>(with screenshots)</font>.
Alan T.
DUH! I missed this when I read the instructions that came with the HP-22.
Thanks!
Old 11-19-2010, 08:52 PM
  #99
<div class="smallfont">Aurora A9, Spectra Pro &amp; Optima - FAQ &amp; Undocumented Features - Mixes, Setups, Tips.</div>
<hr size="1" style="background-color: #a7a7a7; color: #a7a7a7" />
Content has been updated and transferred to Post #101</p>
This as RCU does not provide for Edit/Update to posts after 5 weeks</p>
Alan Tong
</p>
Old 12-05-2010, 11:25 AM
  #100
Heads up -
There have been quite a number of recent new entries and updates edited to existing articles on post #99 at
- Aurora A9, Spectra Pro &amp; Optima - FAQ &amp; Undocumented Features
These include:
. <font color="#22229c"><u>Telemetry - Instruction Sheets </u></font>&amp; User Guide - updatedwith newpictures <font size="1">plus Enhancements Under Development</font>.
. <font color="#22229c"><u>AFHSS - Warning Beeps</u></font> Aurora &amp; Spectra Pro.
. <font color="#22229c"><u>Aurora A9 - Firmware Update V1.08</u></font> due mid Jan11 - <font size="1">preview </font>
. additional items under the Helicopter section
. <font color="#22229c"><u>Spectra 2.4J Module</u></font> - Telemetry Module for JR Transmitters. <font size="1"><font color="#ff0000">NB: 3 different types = Universal, Japan &amp; France </font>- update Nov10</font>.
. <font color="#22229c"><u>Aurora A9 - Transmitter Case</u></font> - Aluminium. <font size="1">(or use for other Hitec transmitters). #553445</font>
. and more.....
Alan T.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
