Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitec Aurora 9 Conditions Question
Old 12-07-2009, 06:23 PM
aa2dd
Default Hitec Aurora 9 Conditions Question
When installing and setting up multiple flight conditions, is it necessary to use switch "C", or can any switch, other than "C" be assigned to conditions?
aa2dd
Bruce
Old 12-07-2009, 08:30 PM
MikeMayberry
MikeMayberry's Avatar
Default RE: Hitec Aurora 9 Conditions Question
No, I think you may be confusing that with the "C" is certain menues which means Combined, this allows the settings/mix/function/etc.. to be ths same in all conditions. You can assign anything you want, including conditions, to any switch. You can also select "S" which stands for Single in which case the setting/mix/etc.. is unique to that condition.
Mike.
Old 12-07-2009, 09:12 PM
aa2dd
thanks Mike. Appreciate the iinformation. The Aurora 9 is looking better all the time!
aa2dd
Bruce
Old 01-14-2010, 01:32 PM
okelly
Hi Mike,
Can the conditions be assigned to stick positions or only to switches?
Old 01-21-2010, 12:19 AM
okelly
Hi Mike,
Any updates on that?
Old 01-21-2010, 12:36 AM
MikeMayberry
Sorry, I must have overlooked your question. Currently flight conditions can only be activated with switches. The only function that has a stick associated with deactivating it is Launch in the Glider mode. Perhaps we could add this later. If you want to supply me with some detailed data about what situatlions it could be implemented in, I.E.... I.E's I'll look into adding it to the wish list.
Mike.
