Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Dual Rudder Servos - Optic 6
Old 02-14-2010, 09:58 AM
KW_Counter
Default Dual Rudder Servos - Optic 6
Good Morning,
For various reasons I am forced to run a seperate servo for the rudder
and the nose wheel. Currently they are using a "Y" connector.
Is there a way I can plug these into seperate channels and program them
to work together - similar to dual aileron servos?
KW_Counter
Old 02-14-2010, 07:42 PM
14MZ flyer
14MZ flyer's Avatar
Default RE: Dual Rudder Servos - Optic 6
Hello KW_Counter
You should be able to program the two together using a P-MIX on your radio. Set one control as the master, and the other one as the slave. Add the amounts of mixing that you require and it should work perfectly.
Refer to your manual for instructions on how to do this, let me know if it works out.
regards
14MZ Flyer
Old 02-19-2010, 11:11 PM
mglavin
My Feedback: (31)
Edit
