Aurora and Mode 1.
Hi Mike!
I changed the software from mode 2 to mode 1.Hardware sticks too.
How to change the warning-sound for high throttle from the left stick to the right one? I bought my Aurora as a mode 2 model from factory.
Is it possible to lower the sound when i program the transmitter?
Thanks in advance!
Best regards,
Erik.
Thanks in advance!
Best regards,
Erik.
ORIGINAL: Erik van Dijen Hi Mike! I changed the software from mode 2 to mode 1.Hardware sticks too.
Is it possible to lower the sound when i program the transmitter? Thanks in advance! Best regards, Erik.
2. Sound is fixed at present, amendments are included in wish list.
Further information available under
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {frequently updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Thanks.
High throttle is in my configuration stick forward.Is it possible to reverse the position of warning/beep?
Regards,
Erik.
Regards,
Erik.
ORIGINAL: Erik van Dijen Thanks. High throttle is in my configuration stick forward.Is it possible to reverse the position of warning/beep?
Regards, Erik.
Regards, Erik.
Subject of several previous posts. Matter is on the Aurora 9 software wish list thread e.g. post #50, and should be available with a future update using
Hitec HPP-22 2.4GHz Programmer Manual
Hitec Programmers - Download Station for HPP-21, HPP-21+ and HPP-22 - Download updates for Aurora , other Hitec 2.4GHz & Digital systems.
Alan T.
Suppose you want to fly one model using one stick mode and a second model on another. Is it possible with the A9?
For example, suppose you fly helis mode 2 and plankers mode 4. Would you have to manually change the mode every time you change models?
ORIGINAL: grotto2 Suppose you want to fly one model using one stick mode and a second model on another. Is it possible with the A9?
Accordingly, as sticks must be changed manually each time a mode change is required, the electronic mode setting is universal across all models.
The Aurora and MPX are the easiest TXto changeas back coverdoes not have to be removed from TX, nor does the spring asembly have to be changed over or a holding block transferred..
Regards
Alan T.
ORIGINAL: grotto2 Swapping between Modes 2 and 4 does not require any mechanical change.
Most upper level Futaba transmitters have assignable sticks for each model selection.
"What's New" - Features ex manual :
6. Switch Assignments
During the model programming steps you will be asked to select what stick,
switch or slider controls the features you want to use with your model.
This gives you unlimited flexibility to choose the most comfortable and practical way for you to use the Aurora.
7. Channel and Control Assignments
The Aurora will automatically select the channel and control assignments based on the model you have.
There is the option to change them if you wish, allowing you a wider choice of receivers that can be used with the Aurora.
..attached .JPG of the Channel Function screen shose how easy it is to change stick assignments for each individual model.
Suggest download copy of the pictorial Hitec 9ch Aurora 2.4GHz_72 mHz Manual, the many screen shots showing why many users arewritingthat the Aurora is the most versatile and easiest to program TX seen to date. Several reviews and How To Program Video available at
Regards
Alan T.
