Max Voltage
CA
Max Voltage
With people starting to use LiPo and LiFe batteries the voltages are increasing.
This is especially true with fully charged batteries.
What is the maximum voltage Hitec receivers, servos and digital servos can handle?
Especially some of the older items.
KW_Counter
KW_Counter
CA
RE: Max Voltage
6.0 volts (nominal voltage) for most servos unless listed higher like on our newer HV (high voltage) servos. Th receiver and buss can handle a higher voltage than what the servos and servo plugs can handle so thats your limiting factor.
CA
RE: Max Voltage
Brendan,
My concern is the fully charged voltage.
A 5 cell Nixx can have 7.0 volts when fully charged.
A LiPo can have 7.6 when fully charged.
Is it safe to use these without a regulator?
KW_Counter
KW_Counter
RE: Max Voltage
ORIGINAL: KW_Counter
Brendan,
KW_Counter
Brendan,
KW_Counter
Mike.
