2.4 and li.ion battiese
Hello everyone
I am setting up my 50cc wild hare edge with a aurora 9 radio system and 5 hitec servos (digital)
I am changing from futaba c9
My battery set up was duel fromeca relion 2-cell li-ion 2600mah
So my question is,do these betties put out enough amps to work safely with my new 2.4 aurora are should switch to something with more amps like a A123 battery
thank you
thank you
thank you for the quick reply mike.
servos are four,hs-5985 and one hs-5955,i don't have any idea what amperage my regulator are,there is nothing stamped on them besides (hamburg h-2, 125 degrees) and troy build seem not to stock them anymore
