Optima 7
NY
Yes, it says Bat/chan7. If you want to use a seperate battery for Rx then that would go into the SPC port. That would only power the Rx.
Have fun!
Jim D
Have fun!
Jim D
ORIGINAL: Riterudder On the optima 7 RX.How do you use Ch 7 with a battery?
ORIGINAL: Riterudder Thanks. Thats what i was looking for.
Optima RX - Multiple Batteries may be installed Dual batteries for redundancy or even one for each servo.
Optima RX - SPC Cable for Optima RX & Use Of SPC Detailed.
Optima RX - A123 2S Cell - Low Battery Warning Auto for 4-5 cell NiMH & 2S Lipol is not currently adjustable for A123 2S.
Optima RX - Servo Move Slower Than Usual -Rebind. Switched between Normal <> Scan mode with power off before process completed.
Optima RX - Servo Wag When RX Turned On Reason & Prevention of Servo Wag (especially when switching on some ESC) .
and more at
Hitec - Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {many FAQpages frequently updated}
Regards
Alan T. (Hitec NZ)
Alan's Hobby, Model & RC FAQ Web Links
I have an optic 6 radio and i purchase the optima 7 combo, but i can´t pair the tx module with the rx, because the rx module have always ON the RED and BLUE led´s when i turn on the radio. Can anyone help me with this situation?
ORIGINAL: ereis8 I have an optic 6 radio and i purchase the optima 7 combo, but i can´t pair the tx module with the rx, because the rx module have always ON the RED and BLUE led´s when i turn on the radio. Can anyone help me with this situation?
As per manual, Transmitter On First - Off Last
RX appears to be in Scan Mode - reset as per:
AFHSS - ID-Setup A.K.A, binding or linking & Range Testing Spectra Pro Module <> Optima Receiver
AFHSS - Normal & Scan Modes Explained includes Redundant (Dual) Receivers.
AFHSS - How To Select Optimum Channels - For Your Field
Regards
Alan T.
I again, the "problem" with my module is when i turn the radio ( OPTIC 6 ) ON , the RED and BLUE led´s of the module TX , stays always ON. I already follow the procedures, like the manual says, with the radio OFF, press and hold the button The two led´s of the module stays ON inclusively the module don´t emite any beep when i press and hold the button, for 2s or 6 s, of the module. I think the module is blocked. when can i do ?
