Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitec Optic 6 2.4GHz
Old 04-30-2010, 10:51 AM
CPH
Default Hitec Optic 6 2.4GHz
I did some checking on a Hitec Optic 6 2.4GHz (158242) So I ordered the Optic 6 2.4GHz, from my LHS, and I think I got the wrong unit. The one I checked out was a little different, The one I got, The power light comes on, but there is no "DISPLAY" the screen is just blank. The unit I checked on says it can do 3 different modulations (2.4/PPM/QPCM) I opened the battery door and it was a 600mAh battery. The unit I checked on had a 1300mAh battery. The box it came in had the old style 72mHz metal antenna on it, in the box besides the transmitter and 2.4 rx there is a small screwdriver, antenna channel numbers and the instructions that don't have anything on 2.4 programming. I am a newbe on 2.4 aircraft radios,(I got a spektrum DX2S for my cars). But I thought all radios will have a display when you turn the radio on! I checked to see that the module was in good, The instructions read that I shoud see voltage and model number. I might have a bad unit. This radio was to be an upgrade, I have an Hitec Eclipse 7QPCM, but I sent it to Hitic for repair. Sorry to go on & on .....Scott
