Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
2.4 antennae adaptor question??
Old 06-16-2010, 09:33 AM
Sourkraut
Sourkraut's Avatar
Default 2.4 antennae adaptor question??
Hi... I purchased a couple Hitec 2.4 module/rx combos for my two Hitec Optic 6 txs and I have a quick question about the adaptor that screws into the TX.
At the base of the antennae adaptor, there is a shim/spacer that is held on with two small screws. When I leave the shim on, the base adaptor does not appear to tighten down firmly. When I remove the shim, the adaptor tightens right down firmly.
Does the shim need to be on there for some unknown to me reason or can I safely remove it and use the antennae adaptor without the shim??
Cheers
Curt
Old 06-16-2010, 09:38 AM
Brendan Lugo
Brendan Lugo's Avatar
Default RE: 2.4 antennae adaptor question??
It does not need to be there. You select the best option for the radio you are using the module in. Some radios you can leave the adaptor and o-ring on the base part of the antenna holder while other radios require that it be removed to properly tighten the antenna base down.
Old 06-16-2010, 11:34 AM
Sourkraut
Sourkraut's Avatar
That's what I was thinking, but thanks for confirming that fact.
Cheers
Curt
