Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Spectra antenna problem
Old 06-19-2010, 09:27 AM
draftman1
draftman1's Avatar
Default Spectra antenna problem
I have a spectra 7 and the big black thing at the end of the antenna wire came off. what is that thing and is it really needed? I didnt see and wire going to it. is it a coil? can I use it with out the black thing? thank you for your reply
Old 06-19-2010, 04:58 PM
A.T.
Default RE: Spectra antenna problem
ORIGINAL: draftman1 I have a spectra 7 and the big black thing at the end of the antenna wire came off. what is that thing and is it really needed? I didnt see and wire going to it. is it a coil? can I use it with out the black thing? thank you for your reply
"I didnt see and wire going to it"
Two types of Spectra 2.4GhzModule, neither refered to as a "7". One attached by a visible wire, the other fixed to case is wired internally. Neither will operate to designed range without the black thing on end of wire.
If Optima 7ch Transceiver, black thing on endof wireis the BODA and Tip - these do effect the range. refer
Optima Transceiver (RX) - BODA Antenna explained - as good, arguably better than a two antenna system.
Optima RX - Conversion for Indoor and Park-Flyers pending release of Minima 2.4GHz series. Hitec "Factory Pilot" Brandon Chitty uses the Optima 7 in his indoor competition aircraft (Fancy Foam Maxima) that weighs 8oz, as well as his 170CC DA powered 42% Aeroworks Yak.
BODA Antenna Tip - If tip's plastic sleeve appears separated at base and is a concern, secure with dab "Shoe Goo" or Heatshrink tube. (The base is soft solder and does not abraid the tip wire.) Mod not required toOptima with an updated tip as supplied from Feb 2010.
In Need, contact Hitec Warranty & Service
Service Form
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old 06-20-2010, 05:49 PM
draftman1
draftman1's Avatar
yes, its the optima reciever I was talking about. ok I guess I will have to send it in. thank you
