Optic 6 using all 6 Channels
I love my new 2.4 module for my Futaba 9C. So far, everything has worked flawlessly. My question is this. I have a number of 6 channel aircraft with a number of new 6 channel receivers.Prblem is that there are only 6 servo ports with the 6th labeled battery aswell. Can I use a Y harness for the batterry tied into the flap servo on channel 6? I have installed this and it seems to work just fine in my 60 size TF P-51. Any repercussions to this setup?
NY
Just make sure your RX battery is big enough to handle things. The 2.4 Rx seem to be more voltage sensitive and power hungry. Avoid brownout!
Jim D
Jim D
ORIGINAL: CRJDriver I love my new 2.4 module for my Futaba 9C. So far, everything has worked flawlessly. My question is this. I have a number of 6 channel aircraft with a number of new 6 channel receivers.Prblem is that there are only 6 servo ports with the 6th labeled battery aswell. Can I use a Y harness for the batterry tied into the flap servo on channel 6? I have installed this and it seems to work just fine in my 60 size TF P-51. Any repercussions to this setup?
more information at:
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
