Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Just looking for confirmation about LIFESource batteries
Old 07-01-2010, 01:16 PM
Bill Rademacher
My Feedback: (77)
Bill Rademacher's Avatar
Default Just looking for confirmation about LIFESource batteries
I had an issue with a new scale FW 190 at the field last night.
Two new HITEC 475HBs caught on fire shortly after I turned the plane on. Rudder and elevator servos. I was using a LIFE source battery, freshly charged at 1 amp. I am thinking it was too much for the servo?
This is in a plane using a DX7 system with an AR7000 receiver.
A small square transistor thingy in the middle of the circuit boards went south to meltdownville.
After I got home, the next day this is what I found:
LIFE Source battery voltage 6.6v
I hooked up the servos to a servo driver and a 5 cell nimh. Flame on just the same.
It seems a little diode in the middle on the circuit board is the thing heating up.
The wing seems fine, but I have 475hb’s and 322hd’s on flaps there. May change them out to be safe. I ordered them at the same time.
Throttle is a 311 and seems fine too.
However, the HS-81 on the retract valve was cooked as well.
Very weird. I may use a voltage regulator anyway, even though the lifesource batteries say in plain print no regulator needed.
I have never had any failures of any kind from HITEC gear, and I use plenty for years. Trans, receivers, servos, etc.
So, I am guessing I cooked them? Is the LIFEsource battery pushing too much voltage right after charge?
thanks
Billrad
Old 07-01-2010, 01:34 PM
arobatx
Default RE: Just looking for confirmation about LIFESource batteries
***removed post...just now realized this is a manufacturer support forum ***
