Aurora 9 trainer cord.
My Feedback: (50)
MO
Here's a good thread on the trainer function. The part numbers you're looking for are in the first paragraph.
Aurora: Trainer / Buddy system Master & Slave function Set-up
http://www.rcgroups.com/forums/showthread.php?t=1090598
Hitec Trainer Cord For Aurora Radios at Tower Hobbies
http://www3.towerhobbies.com/cgi-bin...?&I=LXZRJ1&P=7
CA
Part number 58320 and 58321 are what you need for the Aurora and would allow you to buddy box it to any existing Hitec radio that has a trainer port.
Just a comment re Trainer lead between 2 x Aurora 9 transmitters. --> PN 58320 cable
The "instruction sheet" that comes with the cable is a masterpiece of confusion - well that's how I found it!
I've eventually sorted out how to connect and make it work and wondered if my check list would be of use to others.
Setting up Buddy/Trainer lead (PN 58320)
Between 2 x Aurora 9 transmitters
Cheers
Alastair Rivers
1 October 2015
- Remove module from the “Student” transmitter.
- On the master:-
- Turn on,
- Select the model and confirm “yes” à Ready to transmit – Yes
- Choose “System” screen à Trainer tab
- (If necessary) toggle between “Act” & “Inh” à “Switch”, click to choose activation switch – I suggest that you select either the sprung loaded switch or a toggle switch handy to the throttle.
- Back out of screen – top left corner = [Trainer] OFF
- Click ‘switch’ (showing the activation switch you have chosen)
- Screen then shows the double triangle opposite the switch.
- If you toggle the activation switch, the triangles will alternately show black, but both show “OFF”
- Toggle the activation switch to show the ‘side’ you want to be “ON” and click the “OFF” sign à will then “ON” in box to right.
- Back out of screens = Master Tx set up.
- On the Student Tx:-
- Repeat steps above on the student’s Tx
- To operate:-
- Plug lead into Master Tx and turn on – ready to transmit - No.
- Copy all details of model, channel allocations (if required) and trim adjustments from Master Tx to Student Tx – Set up a “new model” setting, if not already created
- Plug lead into Student’s Tx.
- Ensure that the “toggle switch” (Off / On) is in the “On” position
- Check that when Master Tx toggles to Student, all control surfaces act as expected
- Do range check for both Transmitters (Student’s being “active” from the Master during range check).
Cheers
Alastair Rivers
1 October 2015
