Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Aurora tension on the sticks
Old 08-13-2010, 06:17 PM
LeoS
Default Aurora tension on the sticks
Maybe it's me but how do i adjust the tension on the throttle rachet and tension on the rudder on my Aurora 9.
The manual is confusing to me.
Any help would be appreciated.
Old 08-13-2010, 06:33 PM
A.T.
Default RE: Aurora tension on the sticks
ORIGINAL: LeoS Maybe it's me but how do i adjust the tension on the throttle rachet and tension on the rudder on my Aurora 9. The manual is confusing to me. Any help would be appreciated.
Aurora Transmitter Mode & Stick Tension Change.
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {frequently updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old 08-13-2010, 06:45 PM
JIMF14D
Ijust did the rudder on my A9. Follow the pictures of the rear in the manual. Peel off the small rear rubber grip on the RIGHT SIDE AS YOU FACE IT FROM THE REAR. The hole marked J4 is rudder. The trick is seeing the adjust screws....not easy. Ihad to look in the J3 and J4 holes with a flash light for a bit to find things.
To see the rudder adjust screw you must have the throttle/rudder stick at mid-throttle +_ a little so it lines up with the hole. On my A9 the adjust screws are allen head.
Good luck.
Jim D.
Old 08-14-2010, 07:41 AM
LeoS
Thanks for the advice, specially to center the stick.
All is well now.
Old 08-14-2010, 11:03 AM
JIMF14D
AJ should add that info to his super duper list of HITEC A9 info.
Jim D
