Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
aurora 9 battery
Old 08-27-2010, 05:42 AM
yak-54
Banned
Default aurora 9 battery
what will be a good lipo battery for this TX also do i have to solder a new connector for this battery or they come ready for hitec like futaba and JR
also do i have to change anything in the program
thanks
ilan
Old 08-27-2010, 09:19 AM
TigerI
TigerI's Avatar
Default RE: aurora 9 battery
I'm using a Zippy or Turnigy 2200mah battery fits well in the A9. I cut the connector off of the stock battery pack & soldered on a new connector on the other end to fit the new lipo battery. Works for me.
Old 08-27-2010, 09:23 AM
Brendan Lugo
Brendan Lugo's Avatar
You will also have to go into the power management screen and change the setting to Lipo.
Old 08-27-2010, 09:41 AM
yak-54
Banned
thank you very much for quick answer
Old 09-01-2010, 06:34 PM
JIMF14D
You must fly very long days! My A9 Tx goes 4-5 hours and still has 30% left.
Old 06-04-2011, 06:57 AM
wkevinm
I was searching posts for installing a LIPO into my Hitec A9 TX. Saw your note. I have a spare Turnigy 7.4 V 2200 MAH battery and would like to modify for my TX. Is there a way to get rid of the large wire on the LIPO, or can I come off of the balancing jack to hook into my tx, any pictures help full.
Old 06-04-2011, 02:01 PM
A.T.
ORIGINAL: wkevinm I was searching posts for installing a LIPO into my Hitec A9 TX. Saw your note. I have a spare Turnigy 7.4 V 2200 MAH battery and would like to modify for my TX. Is there a way to get rid of the large wire on the LIPO, or can I come off of the balancing jack to hook into my tx, any pictures help full.
Never use the balancing tap for connection other than the intended purpose - a very weak link in the chain...
Aurora & Optima RX - Battery Compartment Size, Alternate Batteries and 2S Lipo
Best to usean adapter, using plug off original battery (unless kept as a back up) and a Deans plug or for your Lipo as attached.
This also facilitates easy removal/replacement forcharging on your standard Lipocharger.
(and preventspolarity reversal when in a hurry at a later date.)
Hitec Aurora, Eclipse, Flash, Optic, Prism series - Lipo and Field / Fast Charging (also has detail of battery plug)
When fitting a 2S Lipo or alternate battery.
Increase or decrease the thickness of the rubber pad attached inside the battery cover. This to ensure a snug fit which
a. Holds the battery in place to prevent damage to wires or connector.
b. Ensures battery cover does not slip off during use.
[A123 pack cannot be used due to both size and the lower voltage]
ex Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
