Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
RX battery with Hitec 2.4
Old 08-30-2010, 05:22 PM
geneh-RCU
geneh-RCU's Avatar
Default RX battery with Hitec 2.4
I have been flying my Raptors with an A123 2300 RX pack and all is good, I love the Hitec system. My question is about a new 90 size H9 P51. I have a 1650ma NiMH 4 cell pack installed. I have low current servos (non digital) in the plane but I do have 2 JR 4721 servos. Will I have any problems using a 4 cell pack? I have an A123 pack for the plane but the JR 4721's do not work well at the higher voltage.
Old 08-30-2010, 07:29 PM
A.T.
Default RE: RX battery with Hitec 2.4
ORIGINAL: geneh-RCU I have been flying my Raptors with an A123 2300 RX pack and all is good, I love the Hitec system. My question is about a new 90 size H9 P51. I have a 1650ma NiMH 4 cell pack installed. I have low current servos (non digital) in the plane but I do have 2 JR 4721 servos. Will I have any problems using a 4 cell pack? I have an A123 pack for the plane but the JR 4721's do not work well at the higher voltage.
JR Servos - Warranty void most JR servos used above 4.8V - Do not use above 6.0v fixed. is correct.
Whilst a 1650 NiMH pack would not normally be a problem, dueto the verydifferingresistances, it certainly will cause problemsif the cells are smaller than AA size such as the AEor AAA used in some lightweight RCapplications. NB: Never fast charge AANiMHreceiver packs.
Aurora A9 - Battery is not charged.has some good information on NiMH batteries.
A123 cells, use with caution, pleasecheck specs against Optima Transceiver (RX) - A123 2S Cell
- Low Battery Warning not adjustable V1.04<06. How to set alert voltages V1.07. Warning regarding use of Eneloop & A123 2S as RX batteries.
The Optima receivers provide a Supplementary Power Connection. This is a dedicated receiver power supply which is not affected by any fluctuations on the servo side and"brownouts", unless uncharged/faulty battery is used,are negated. Simply install another switch and a small 2S lipo or another small RXbattery as detailed Optima Transceiver (RX) - SPC
H9 P51 can easily carry an extra RX battery:
Optima Transceiver (RX) - Multiple Batteries may be installed.
Dual batteries for redundancy or even one for each servo, mayprovide furtherpeace of mind.
more:
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old 08-31-2010, 04:48 AM
geneh-RCU
geneh-RCU's Avatar
Thanks for the info. I am using true A123 cells from Andy Low (ElectroDynamics) and I use his checker. I know how much is used for each flight (average) and I know when to stop flying. I did not know about JR servos not being rated for 6 volts. The specs show a torque and speed at 6 volts.
Old 09-01-2010, 02:05 PM
JIMF14D
Hey, tell me a little about that hot looking airplane in your avatar!
Old 09-02-2010, 03:26 PM
geneh-RCU
geneh-RCU's Avatar
That is a Super Reaper, It has a Ram 750 turbine on it. I have been flying it for a few years now. I have not converted it over to 2.4 yet but plan to in the future.
