aurora program for engine kill
Hello. I'm looking to get some programming help using a aurora 9 radio. I'm trying to install a smart fly ingition cut off. I have installed it to channel 7 on my receiver. I would like to assign switch H as the switch to kill the engine using the smart fly cut off unit. How would I do it???
Thanks for your help. |
RE: aurora program for engine kill
I am sure there are lots of guys here who have set this up and used it that know more than me. But here is a way to run channel seven from switch h so it goes on off with that switch using the fuel cutoff name:
Turn on the tx and hit the "wrench" select "channel" Select channel 7 and select fuel and then hit set Now channel 7 should read "fuel:null" Now hit "null " and a control stick/switch menu should come up hit "H" and "set" to make switch H control channel 7 back up to the previous page and channel 7 should show "fuel:H" Go back to the wrench and hit it. hit model and then monitor Throw switch H back and forth and you should see channel 7 servo commands go full throw to either end You might have to reverse channel 7 direction to get the signal to match your ignition control thingie Good luck..........I hope this works for you! Jim D PS: I think you could leave it as AUX if you want and just hit "null" to go to the switch select menu. |
Hi Jim,
Thanks for your help. I've tried your programming suggestions, but when I have the throttle at any setting eg. full ,and I hit the programmed kill switch , nothing happens ( the throttle stays at the open position.) Or do I have this all wrong?? I'm thinking the throttle servo must reset back to the off position , but perhaps the battery current to the engine only would be stopped, thereby killing the engine , regardless of the throttle position. |
<span style="font-size: smaller;"> ORIGINAL: peter baldino Hi Jim, Thanks for your help. I've tried your programming suggestions, but when I have the throttle at any setting eg. full ,and I hit the programmed kill switch , nothing happens (the throttle stays at the open position.) Or do I have this all wrong?? I'm thinking the throttle servo must reset back to the off position , but perhaps the battery current to the engine only would be stopped, thereby killing the engine , regardless of the throttle position.</span> perhaps both sides are set to Off or On.. 2. All electronic switches work on same basis as an ESC. EPA may need to be extended: . EPA, ATV, Dual & Triple Rates, Expo Differences & Caution includes ESC / BEC Set Up. These may also assist: . Aurora 9 - Switches Re-assign/Swap Switches and or Functions "F" & "H" - DIY notes & Replacement Switch part Numbers.. . Aurora 9 - Throttle Control - Glow Driver &/or Ignition On/Off <font size="1">post #2239</font> . After Market Accessories - Ignition Systems, Leads, Modules & Switches - Cautions. ex Hitec USA Support Forum Sticky: Aurora 9, AFHSS Modules, Optima & Telemetry - FAQ & Undocumented Features - Mixes, Setups,Tips. {Individual Links often updated} Alan T. [url=http://homepages.ihug.co.nz/~atong]Alan's Hobby, Model & RC FAQ Web Links[/url |
