Setting up Eclipse 7
I've been using an Eclipse 7 for a season now (and enjoyed every moment). I am adding a second aircraft. I've been able to set all the control throws but when I go to set up the throttle, I can't set the trim to the recommended 25%. When I get to the trim menu and go to ch3, trim is set at 0% Moving the trim switch in a + direction changes nothing. Trim operates fine in - direction. Throttle was retarded but not completely. What am I doing wrong?
TIA Mike |
RE: Setting up Eclipse 7
I'm a little confused. I think the best thing to do is call us to discuss this.
(858)748- 6948 Mike. |
