Hitec 225 for DP Ultimate ailerons?
Mike,
I have an DP 120 Ultimate. I will probably go with the 5945's on rudder & elevator. My question/concern is this: Would you recommend the 225's on the ailerons for this model. The DP Ultimate requires 4 servos, one per aileron. I would really like to use a "mini" servo due to size and weight! I'm just concerned if the 225's will hold up in this application..... Thanks for any input and advice. EdMan |
RE: Hitec 225 for DP Ultimate ailerons?
I know Dave himself uses the 5245's which are the digital version so they will work but make sure to get the MG version.
Mike. |
