hey mike, focus 6 trouble
Mike hitec service,
i have a focus 6 im having trouble with ch 1 right stick, left right cylic. radio glitch, powered up tx then rx with no stick movement the hs81 servo goes crazy. with rapid cycling back an forth an buzzing. then bound up at one end of its stroke still buzzing . thinking i had stripped a gear i opened the servo up an the output gear was stripped. i replaced the gears an tried it again, an it did the same thing.an stripped the output gear. ouch then i tried it with a standard size servo an it went crazy an buzzing but did not strip the gears. now im thinking i have an rx or a tx problem. i also have a focus 4 an 2 hitec receivers so i did some troubleshooting by swapping back an forth between rx 's an tx's, an determined that there is a problem with the focus 6. it glitches on both rx's with the focus 4 , no glitch on both rx's the symtom described ,what do you think is wrong with my tx? is there anything i can try , to fix this? before i send it in for repair what would be a typical cost to repair this tx? crash |
RE: hey mike, focus 6 trouble
It's tough to say what the cost would be but it is free to find out. I'd send it in and let us check it out.
Mike. |
hey mike,
help i took your advice an sent my tx an rx to hitec service to have checked out. shipped it ups store 1/16/04 cost me $16.59 to ship it to hitec [:'(] checked tracking hitec got it 1/22/04 1/28/04 i emailed hitec to check status brendan emailed me back 1/29/04 "Hello We have received your radio. Our tech will probably be working on this order today. Regards,Brendan Lugo" then i received a hitec postcard 1/30/04 stating hitec had recieved it. havent heard anything since 2/5/04 ups dropped a package off from hitec [:-] is it christmas i opened the box theres my focus 6 an rx, but wait where is my tx antenna [X(] rumaging through the packing paper its not in the box! i cant wait, i took the antenna of my focus 4 an put it on the focus 6 to try it out put a servo on rx ch1 plugged battery in powered up guess what, its doing the same thing [&o], buzzing servo erratic movement binding up ch 2,3,4 same servo works fine well what does the service ticket say "recalibrate gimble" thats it, thats all it says about the tx what does that mean whats up mike i expected some hitec service! [&o] is that my antenna on your desk, you had a big board meeting an an your using my antenna as a pointer arent you LOL:) seriously mike i need some help to get these problems resolved i can say this i was not charged for the gimble calibration an it was shipped back to me at no charge. an for that i am thankful Robert |
