hs 805 bb
:D
Hallo Mike, I'll use two HS-805BB on my 1/3 scale glider, one for the tow release and the other on the rectractable landing gear...these servos won't work at the same time: any suggestions to connect the same 6V battery pack only for these servos?? Thanks |
RE: hs 805 bb
Describe your present installation and equipment in use?
Did the servos come with a wye power connector? |
RE: hs 805 bb
1 Attachment(s)
:DThis servo has a high current drain, and it is recommended to use a separate high capacity 6V battery....is it correct the configuration ?? See figure:
Thanks Alfo |
RE: hs 805 bb
Alfo
This will work. There will be a problem with the five cell pack on the servo wyes. If you want to run the five cell pack, I would remove the power pin from the wyes that allow 6.0V to travel to the RX, which has its own four cell 4.8V battery.. Or simply use two five cell 6.0V batteries. |
RE: hs 805 bb
:D:D Thanks Mike.
