Dual rates with elevons
I don't have my Eclipse 7 manual to hand (and I'm incredibly lazy) so I was wondering if someone clarify the situation in respect to dual rates and expo settings when using the elevon mix.
Last time I used this mix, I got the impression that the rate and expo settings were applied at the channel level rather than at the stick level -- ie: if you wanted expo or dual rate, you had to have it set on both ailerons and elevator and have it set to the same on both channels. Is my memory failing or is this a limitation of the E7's elevon mix? |
RE: Dual rates with elevons
The dual rates and expo applies to the function not the channel. It will work fine.
Mike. |
