yo , mike, eclipse and heliS!
ok hi there, i got an eclipse 7 with the version 12 software , an rcd3500 rx and a kyosho concept sr-e, in the manuel it says aileron-1 , elavator-2, throttle-3, rudder-4 , gyro-5 and pitch-6, however, i have a pg-1 gyro and the rudder servo is plugged into that, so should i plug the gyro into the gyro port or the rudder port?, also, i noticed that the pitch increases ( or tries to) when i add throttle, is this supposed to happen? because thats reversed with me, and i cant reallly reverse the throttle servo can i? also, the rudder looks reversed and servo reverseing on it isnt doing anything..
RE: yo , mike, eclipse and heliS!
The rudder/tail rotor is plugged into what channel?
Generally the gyro is plugged into channel 5 as rate or on/off function and the tail rotor/rudder uses channel 4. Pitches increase with throttle so the helo will lift off the ground. See the pitch curve to fine tune the response. |
| All times are GMT -8. The time now is 11:08 PM. |
