RCU Forums
-   Hitec/MultiPlex Radios- Ask Hitec Customer Service (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/)
-   -   Which Servo for 3D? (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/1875694-servo-3d.html)
Crash Master 06-05-2004 03:16 PM
Which Servo for 3D?
I realize that this may be a stupid question, but I got to ask it anyway.
I am learning to fly 3D and fly the SPA3D and SPA3DT. Originally I installed HS-300's in both planes and have a nasty habit of stripping them out quite easily (watched a fly land on one of the ailerons last weekend and stripped the servo :D).
I found out that the HS-300's have been discontinued for over 3 years and were primairily designed for trainers (maybe that's why I have so many of them ;)). That would account for them stripping out so easily.
My question is, which of the Hitec servo's (keeping cost in mind) would be better suited for these 3D birds? I have a few HS-422's and some HS-425BB's that I recently got. Would these work enough to prevent the flies from stripping the gears out?
Any and all suggestions, advice and/or information will be greatly appreciated.
MikeMayberry 06-07-2004 01:48 PM
RE: Which Servo for 3D?
You may have slightly better results with the 422/425's but they are still a similar material. I would look at the 475's which use the Karbonite gear train which is 4 times stronger. The next step would be the 525MG.
Mike.
