Servo programmer
Hi Mike---I have the "Hitec Servo Programmer" & cannot keep the on/board battery charged ---After I use it, (nice tool!) which is not very often, & then in a week or two, try to use it again, the battery is completely dead. Have tried different battery...same thing. there is obviously a small current drain with switch off,(batteries will stay charged when removed from unit). Is this normal?---Please advise---
Later Ed |
RE: Servo programmer
Ed
Unfortunately its normal behavior for the programmer. It has something to do with the power routing. |
ORIGINAL: mglavin Unfortunately its normal behavior for the programmer. It has something to do with the power routing. It sounds like unplugging or pulling out the battery is a good idea -- if it's user-accessible. I suspect this is the price one must pay for not having a good old fashioned mechanical power switch. |
Well......But it DOE"S have an "On/Off" switch---Go figure---
They all do it... I've never had one go into cut-off or cell death / reversal though. Just got into charging before use since it is not used very often.
DP |
| All times are GMT -8. The time now is 12:36 PM. |
