RCU Forums
-   Hitec/MultiPlex Radios- Ask Hitec Customer Service (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/)
-   -   help (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/2646733-help.html)
cyrrus 02-11-2005 02:45 PM
help
HELP.
Hi there I'm just getting back into the RC world. Okay this Is what I have. I purchased a used futaba 3pj came wtih Hi tech spectra module model # hp-pll(pcm/ppm) the Rx is a HI-Tech dcx. I running it in a RC 12l4( probably info not needed) Novak Atom. and A Airtronic micro servo 94145.
Okay my problem is this. When I first got the radio and tried it I work the steering but no throttle. then noticed the throttle was set at zero. I was looking and cleaning the radio. Then yesterday I finally got a charger. Was going to get the car dailed in. There is no response from the Rx and the TX. the battery is fully charged. And yes both were on. I was going through the menu and trying different things. I read from the on-line manual I had to have it in ppm which is is, The RX icon on the LCD screen on the 3pj does not come on. In which I believe is telling me that there not signaling to each other. So my question is What do I do. and the other would be is there any way to reset the 3pj back to original default. As you can see I almost wrote a novel. but i'm in need of major help. My first race is tomorrow night and I'm going to be hooped. Plus I also found out nobody in my club has ran this radio.
PLEASE HELP ME
Amdrew
Brendan Lugo 02-14-2005 01:56 PM
RE: help
Check your manual as there should be some sort of reset option to set the model back to a factory default. Other thinks to check are the ESC (atom) to make sure it is operating properly. If it is not it will not supply power to the receiver and the transmitter will not communicate to the receiver.
