question about hitec flash 5x
MIKE---I HAVE A HITEC FLASH 5X SYSTEM--WOULD LIKE TO KNOW IF IT IS POSSIBLE,WHEN USING AILERON ,RUDDER COUPLING---TO TURN IT OFF OR ON WHILE FLYING WITHOUT GOING THRU THE MENU SEQUENCE---WHICH WOULD BE IMPOSSBLE TO DO WHILE FLYING.
THANKS FLYMAN 1 |
No, it is only selectable in the programming. You would need to get the Eclipse to be able to turn it on and off at will.
Mike. |
