problem with laser and reciever
ok i just got into rc flight and i wanted to buy a radio. i bought a radio from a seller on rcunverse marketplace
it came with a 8 channel rx and laser 4 tx i ended up losing the plane so i decided to buy a new reciever i fly park flyers so i went for the feather reciever. i checked my radio system and it turns out that it runs off 75mhz so when i put the crystals in both rx and tx nothing happened. is there anything i can do to make this work or would you suggest a different reciever what should i do thanks |
RE: problem with laser and reciever
You'll need to have the laser converted to 72Mhz in order to fly a plane. Follow the instructions in the sticky at the top of this forum to send it in.
