RCU Forums
-   Hitec/MultiPlex Radios- Ask Hitec Customer Service (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/)
-   -   5955 Problem (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/3315603-5955-problem.html)
mxcop114 08-30-2005 10:51 PM
5955 Problem
Hi,
I just got a 5955 along with 4 5945's. When I plug in the 5955 it glitches bad when I move the rudder. It will move ok then all of the sudden glitch bad, causing the elvator servos to glitch also. I'm running duralite 7.4 4000mah with 6v regulator. Anyone have any ideas what might be wrong? Thanks
mglavin 08-31-2005 02:17 PM
RE: 5955 Problem
Please expand on the model specific installation of the radio gear and servos as well as the RX brand and model. Where are the servos installed, wyes, extensions boosted or amplifed? Do all the 5945's glitch?
mxcop114 08-31-2005 10:52 PM
RE: 5955 Problem
Problem solved, it was a bad receiver. I tried a new pcm and everything works perfect. Thanks
