Programming Question
I'm in the process of programming my 5955 servos. I've completed the aileron and rudder servos without any issues. I have a question about the servo on my elevator channel though. On low rates, the servo moves as expected throughout the entire travel of the TX stick. But, when I switch to high rates the servo does not move for the entire travel of the TX stick. With the stick in the neutral position, I give down elevator input and the servo moves through about the first half of the TX stick's travel but doesn't move through the remaining stick travel. Giving stick input for up elevator, the same thing happens. Again, this happens only on high rates.
I checked the TX pulse on the elevator channel with the programmer and found that on high rates the TX outputs' are 879 us and 2080 us. For comparison, the TX endpoint pulses on low rates are 1197 us and 1759 us. Since the programmer's Operation Manual says the normal endpoint parameters are 2100 us to 900 us, is the problem that one of my TX's pulse outputs on high rates is 879 us? If so, why does the servo's movement not follow the TX stick's movement in either direction since one of the TX's pulse endpoint values is within the servo's normal endpoint range? In order to have the servo move throughout the TX stick's full travel, should I program the servo's one endpoint value to be less than my TX pulse (i.e., 875 since the servo is 879)? Thank you. Dan |
RE: Programming Question
The pulse should NOT be a problem at 879us, or even much lower for that matter.
I'd try reprogramming the elevator servo, you never know. |
Thanks, Michael. I tried resetting and then reprogramming the servo but get the same result. What else should I try?
Dan |
Are you sure this is a 5955 servo verses a 5995 as this would make sense in this circumstance.
Can you try another servo on this channel to validate the servo is the culprit? |
Are you sure this is a 5955 servo verses a 5995 as this would make sense in this circumstance. Can you try another servo on this channel to validate the servo is the culprit? I connected my rudder servo to the elevator channel and get the same result. The servo for the other elevator half, which is running off a separate extension on an AUX channel (mixed with the elevator channel), also stops moving like the servo on the elevator channel when on high rates. It doesn't seem like a servo problem since all 3 do the same thing.(?) Dan |
Can you try another servo on this channel to validate the servo is the culprit? Dan |
What is the end point setting on the radio and on the programmer?
When I program my 5945s for elevator servos , I used 130 on radio, and about 120 on the programmer. Set the neutral to 0 on radio as well. |
Try utilizing another model memory maybe something is occurring in the mixing. Not being familiar with the TX in hand can you verify the MIX or D/R is not minimizing end-point percentages? However you did suggest the Programmer divulged the control signal was in the zone previously for High and Low rates when toggled; this is an interesting anomaly...
What is the end point setting on the radio and on the programmer? When I program my 5945s for elevator servos , I used 130 on radio, and about 120 on the programmer. Set the neutral to 0 on radio as well. My programming values on this particular servo came out to be -88 and +110. My subtrims are all set to zero. Try utilizing another model memory maybe something is occurring in the mixing. Thanks for the suggestion, Michael!:D Dan |
| All times are GMT -8. The time now is 12:22 PM. |
