Flash 5 sx PROBLEM
I have a flash 5 that seems to have numerous problems
MAIN - I have a flying wing I bought this radio to fly - I put it on model #3 ACRO setting ELEVONS on servos (hs81's) - plugged into 1 & 2 Reciever 555 When I push stick right everything ok Left - everything ok If I push stick down (dive) elevons go up !! I pull it back (climb) elevons go down !! I tried reversing each servo and reversing both - Nothing... I also cant get it to set the EPA right.... I am getting real upset with this radio. By the way, I bought mine the same time my flying buddy did - he has the exact same problems !! HELP HITEC !!! |
Flash 5 sx PROBLEM
Try this:
Switch where #1 and #2 servos plug in with each other. I had the same problem with a v-tail and this solved it - then I was able to use servo reversing. Not a problem with the radio at all. My Flash 5x works great! (especially now that it is fixed for free by hitec) |
Flash 5 sx PROBLEM
Did that fix it? It should.
Mike. |
