5985
Got a new 5985 and installed it on the elevator of a new 35% when I move my sticks on my 9Z the suface moves in a stepping motion at 100ATV it is more obvious and enough to shake the plane, installed 5955 and it doesnt do this. Linkage is so free I can blow on it to make it move, could it be burrs on the gears, btw only does it in one direction. gear sets I have are for 5945s do they fit?
RE: 5985
I've not heard of such an issue. It sounds like the servo may be defective... especially if it only does it in one direction. I really doubt that the gears would cause this.
I would send it in to have it checked out. Mike. |
RE: 5985
Thanks Mike, although its the same thing as the post by Sillyness on the 5955, I checked linkages etc and all are good,btw it only shows up when moveing slowly from endpoint to neutral.
