Dual elevator servos
How do you setup the Optic 6 for a plane that has dual elevator servos?
RE: Dual elevator servos
ORIGINAL: Flipper430 How do you setup the Optic 6 for a plane that has dual elevator servos? Your topic is well covered page 39 & 40 of the Optic 6 Manual. AILV - Ailevator Function Setting Up the Ailevator Function 1. This function requires two elevator servos, one for each side. Plug the right elevator servo into channel 2, and the second elevator servo into channel 5. If you need retracts, you will have to use the output from channel 6. 2. Call up the mixer screen by repeatedly pressing the Edit Up or Down key until the AILV window appears. The default is for the function to be inhibited. To activate, press the CLEAR key. This will cause the AILV INH display to change to AILV ON. AILV is not a switch able function, it is either ON or OFF. 3. Move the stick to command aileron. In addition to the aileron servo(s), both elevator servos should move. They may move in opposite directions (as they should) or the same direction (instructions for correcting this are below). 4. Move the stick to command elevator. Both elevator servos should move. They may move in the same direction (as they should) or opposite directions (to be corrected below). 5. Press the Cursor Right key to get to the travel setting menus. The display shows a triangle over the number 1 and under the number 2, indicating you are in the AIL->CH2 setting menu, programming the response of the CH2 elevator servo due to aileron (CH1) commands. 6. If the elevator servo plugged into CH2 goes the correct direction with aileron stick, go to the next step. Otherwise, press the Data +Increase or -Decrease keys to change the sign of the percentage displayed. If it is (+), change it to (-), or vice versa. Only change the sign of the number, you can decrease its value later if you need to. 7. If the elevator servo plugged into CH5 goes the correct direction with aileron stick, go to the next step. Otherwise, press the Cursor Right key to get to the AIL->CH5 setting menu, then press the Data +Increase or -Decrease keys to change the sign of the percentage displayed. If it is (+), change it to (-), or vice versa. Only change the sign of the number, you can decrease its value later if you need to. 8. If the elevator servo plugged into CH2 goes the correct direction with elevator stick, go to the next step. Otherwise, press the Cursor Right key to get to the AIL->CH2 setting menu, then press the Data +Increase or -Decrease keys to change the sign of the percentage displayed. If it is (+), change it to (-), or vice versa. Only change the sign of the number, you can decrease its value later if you need to. 9. If the elevator servo plugged into CH5 goes the correct direction with elevator stick, go to the next step. Otherwise, press the Cursor Right key to get to the ELEV->CH5 setting menu, then press the Data +Increase or -Decrease keys to change the sign of the percentage displayed. If it is (+), change it to (-), or vice versa. Airplane Model Function Descriptions - Page 40 10. Once you have all the servos moving the correct directions, you can go back and adjust each of the travels independently, so that both elevator servos move up the SAME amount when elevator control is given, and move opposite the same amount for aileron command. You will need to decrease the percentage shown for the one moving further, or increase the percentage for the one moving less. Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links |
Thanks for the help,i am out of town and dont have my manual and yes the hitec site is down as i had tried that also.
| All times are GMT -8. The time now is 01:13 PM. |
