Antenna radiation pattern
I have Hitec Prism 7.
Do you (=Hitec) have any studies about the TX-antenna radiation pattern about abovementioned radio, specially in the direction of antenna axis. Hard to believe that there is a sharp null field strength at the tip of antenna. Measurement , that I did, did not support that opinion. What shall I believe in? Osmo H |
Antenna's transmit outward, that is why you don't want to point it directly at the airplane. I wouldn't worry about it though... it has never been an issue.
Mike. |
| All times are GMT -8. The time now is 03:58 PM. |
