HPP or HFP ?
I just wanted to know if the HPP and the HFP programmers have the same functions ? I purchased some used HS-5625MG servo's that work fine except two are reversed. I have no problem with that but I don't know if they changed anything else. Seem to have the same travel and speed just running backwards. Does the software have the factory servo settings when using the HPP21 or HPP21 plus ? Are there any major down sides to the less expensive ones except portability?
Andy |
RE: HPP or HFP ?
ORIGINAL: AJsToyz I just wanted to know if the HPP and the HFP programmers have the same functions ? I purchased some used HS-5625MG servo's that work fine except two are reversed. I have no problem with that but I don't know if they changed anything else. Seem to have the same travel and speed just running backwards. Does the software have the factory servo settings when using the HPP21 or HPP21 plus ? Are there any major down sides to the less expensive ones except portability? Andy It is prudent,when buying second hand digital servos or swapping from one model to another, to test and reset each one to factory default before re-using them. There can never be any certainty as to what a previous user has input, even minor adjustments can cause problems in other models. Many users quickly forget which servo has or has not been reprogrammed. HFP-10 Digital Servo Programmer FAQs Digital Servo Instruction Videos - HFP-10 programming An earlier product announcement New High Performance Digi Servos From Hitec . NB: All G2 premium digital servos are equipped with coreless motors and dual ball bearings. Here is the comparison chart between the programmers and Hitec digital servos. Servo Test & Programmable functions of old HFP-10 (Which can not be upgraded but may possibly be exchanged at a reduced cost subject to direct application to Hitec service): Manual and Automatic testing procedures, Transmitter Pulse width measurement, Receiver Voltage measurement, Direction of Rotation, Speed of Rotation, Fail Safe On-Off, End Point, Neutral Point, Fail Safe Point Preset Servo Test & Programmable functions of New HFP-20 : Basically Same as old HFP-10, and "Overload protection Setting" and "Servo Resolution mode Setting" Function added. Programmer........Function...................Conve ntional........HS-50xx..........HS-7xxx .................................................. ..........HS-5/6xxx.........Digital Micro.....Digital .................................................. ..........Digital Servos......Servos...........Servos HFP-10 & 20........Servo Test..............................Yes..........Yes .................Yes .........................RX Pulse & Voltage Measure.......Yes..........Yes.................Yes .........................Reset.................... .................Yes..........Yes................. Yes .........................Dead Band Setting...................Yes..........Yes........ .........Yes .........................Servo Speed...........................Yes..........Yes.. ...............Yes .........................Change Rotation (CW/CCW).......Yes..........Yes.................Yes .........................Fail Safe On/Off.......................Yes...........Yes....... .........Yes .........................EPA/Fail Safe Position...............Yes...........Yes.......... .......Yes ......... HFP-20 ........................Overload Protection...................No.............Yes... ...........Yes ........................Resolution Mode Setting.............No..............No............ ...Yes G2 The Second Generation Premium Digital Servos (HS-7XXX series) *Overload protection : This function is to protect the servo(HS-50XX servos & HS-7XXX servos) from the overload condition. Once the servo is forced with overload condition for certain time, the motor output will be decreased to the setting level set by user. Please note that this function is deactivated (off) in factory setting.(factory default : overload protection off) *Resolution mode setting : There are two resolution modes(High and Normal) in HS-7XXX servos. Factory default is set at "High" resolution, and servo travel will be 120 degree. If user needs to widen the servo travel, user may select normal resolution so that the servo travel can be widened to maximum of 180 degrees. (Factory default : Resolution mode High) "NOTE" : These new functions (Overload protection Setting & Resolution Mode Setting) can be programmed by new Hitec servo programmer, HFP-20 . HPP-21 HPP-21 Plus HPP-21 RCU discussion - new PC based Hitec Digital Servo Programmer to be released shortly. HMI Digital Servo Programmer for Robotics servos, • Compatible with the following DIGITAL servos: HSR-8498, HSR-5990TG,HSR-5980SG,HSR 5498SG, Hitec Digital ROBOT Servo. Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links |
RE: HPP or HFP ?
I was going to go ahead and get a programmer to reset the factory settings. The new PC based programmer is only 20.00 , and 39.99 for the one with a nob onit to do feild testing and programming. Sounds like they should have the same capabilities as the HFP20 just on a USP cable from a PC or laptop.
Andy |
RE: HPP or HFP ?
1 Attachment(s)
Updating post #2 - as above links no longer valid and add attachment notyeton new Hitec site. NB: It is prudent,when buying second hand digital servos or swapping from one model to another, to test and reset each one to factory default before re-using them. There can never be any certainty as to what a previous user has input, even minor adjustments can cause problems in other models. Many users quickly forget which servo has or has not been reprogrammed. HFP-10 Digital Servo Programmer FAQs Digital Servo Instruction Videos - HFP-10 programming Videos x 6 which include "Linear setup multiple servo" & "RudderServoProgramming". An earlier product announcement New High Performance Digi Servos From Hitec . NB: All G2 premium digital servos are equipped with coreless motors and dual ball bearings. Here is the comparison chart between the programmers and Hitec digital servos. Servo Test & Programmable functions of old HFP-10 (Which can not be upgraded but may possibly be exchanged at a reduced cost subject to direct application to Hitec Service ): Manual and Automatic testing procedures, Transmitter Pulse width measurement, Receiver Voltage measurement, Direction of Rotation, Speed of Rotation, Fail Safe On-Off, End Point, Neutral Point, Fail Safe Point Preset Servo Test & Programmable functions of New HFP-20 : Basically Same as old HFP-10, and "Overload protection Setting" and "Servo Resolution mode Setting" Function added. Programmer........Function........................ ..Conventional........HS-50xx..........HS-7xxx .................................................. ..........................HS-5/6xxx.........Digital Micro.....Digital .................................................. ..........................Digital Servos......Servos...........Servos HFP-10 & 20........Servo Test..................................Yes......... ........Yes.................Yes .........................RX Pulse & Voltage Measure.......Yes.................Yes............. ....Yes .........................Reset.................... .............................Yes................Ye s.................Yes .........................Dead Band Setting...........................Yes............. ..Yes.................Yes .........................Servo Speed......................................Yes.... ............Yes.................Yes .........................Change Rotation (CW/CCW).........Yes................Yes............... ..Yes .........................Fail Safe On/Off.................................Yes........... .....Yes................Yes .........................EPA/Fail Safe Position....................Yes................Yes .................Yes ......... HFP-20 ........................Overload Protection............................No.......... ....Yes................Yes ........................Resolution Mode Setting...................No...............No..... ............Yes G2 The Second Generation Premium Digital Servos (HS-7XXX series) *Overload protection : This function is to protect the servo(HS-50XX servos & HS-7XXX servos) from the overload condition. Once the servo is forced with overload condition for certain time, the motor output will be decreased to the setting level set by user. Please note that this function is deactivated (off) in factory setting.(factory default : overload protection off) *Resolution mode setting : There are two resolution modes(High and Normal) in HS-7XXX servos. Factory default is set at "High" resolution, and servo travel will be 120 degree. If user needs to widen the servo travel, user may select normal resolution so that the servo travel can be widened to maximum of 180 degrees. (Factory default : Resolution mode High) "NOTE" : These new functions (Overload protection Setting & Resolution Mode Setting) can be programmed by new Hitec servo programmer, HFP-20 . EPA settings. The programmer sets the end points at 900, 1500(center), 2100us when you use the EPA programming mode. If your transmitter is not sending a wide enough pulse at it's end points, you will not see the same end point travel you set with the programmer. Increase the EPA settings in your transmitter for the channels you have the programmed servos on, this so you should be very close to the end points you programmed. HPP-21 HPP-21 Plus HMI - Digital Servo Programmer for Robotics servos. • Compatible with the following DIGITAL servos: HSR-8498, HSR-5990TG,HSR-5980SG,HSR 5498SG, Hitec Digital ROBOT Servo. Digital Servo FAQ Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links</p> |
| All times are GMT -8. The time now is 09:23 PM. |
