RCU Forums
-   Hitec/MultiPlex Radios- Ask Hitec Customer Service (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/)
-   -   Programming problems with 7955 (https://www.rcuniverse.com/forum/hitec-multiplex-radios-ask-hitec-customer-service-53/8849833-programming-problems-7955-a.html)
tymt 06-13-2009 08:15 PM
I have 4 new 7955 servos. Two on each elevator. I programmed two of them successfully with the HFP 10. The problem is that when I went to set center and enpoints on the other two servos. When I plug in the progammer and select Center and Endpoint function the servos don't stop moving. They continuously move from about +25 to -25. Any suggestions.
MikeMayberry 06-16-2009 12:24 PM
RE: Programming problems with 7955
I've not heard of that before. I would try resetting the servos first.
Mike.
tymt 06-16-2009 08:29 PM
have tried that several times and it has no effect. Also, the servos work normally when connected to a receiver. I have ordered aHPP-21 programmer and am going to try that next.
