7955 programming
Ok, I am stumped. I thought the servos come with a default swing of 120*. Right now I only get 80* max. I tried to program for more throws but it only goes 40* each way. What am I doing wrong? I am using the -20 programmer. Please advise.
PS: My radio is in default condition. No mixing, dual rates, etc... Please advise. Azhar |
RE: 7955 programming
Increase the radios EPA and D/R to maximum.
Thanks Mike
But why? I do not have to do that to the 5955s. But after messing around a little, I found that in the low res mode, it will allow you to go past 40* of throw. Does this mean that it is running at 1024 now? |
The high resolution mode is limited to standard travel (about 90 degrees) but you can get a little more if you max out the EPA and D/R. If you need more travel at the control surface then you will need to use a larger horn. Changing to low resolution mode defeats the advantage of improved resolution of the 7XXX series servos.
Mike. |
| All times are GMT -8. The time now is 04:17 PM. |
