90* CCPM for Eclipse
Hello Mike is it true the Eclipse will not support 90* CCPM as is used by the ECO 8 electric heli? Setting the swash menu to normal does not seem to do it. Is there any way to get the Eclipse to do 90* CCPM with a custom mix or variation of 180* CCPM? I really dig this radio and would be disappointed to hear it can't perform this simple function. Thanks in advance.
The 90 degree mixing is for normal, not CCPM. However, there are many people using the 180 CCPM with the two P-mixers to get the desired affect for that chopper.
I would suggest a search on http://www.ezonemag.com for posts on this exact issue. Mike. |
thanks for the tip
ok Mr. Mayberry I will check that out. I appreciate the reply. Happy landings.
| All times are GMT -8. The time now is 06:00 AM. |
