Timing the Flap/Elevator mix
I've set a little elevator mixing with the flaps but I have set the flaps to lower and raise slowly (5 secs.down and 3 secs up.).
The problem is the elevator reacts instantly while the flaps are slow. How do I slow the elevator to go in time with the flaps without actually slowing the sevo so I can use the elevatornormally? I could always remove the timing on the flaps and move my finger slowly, but it's not quite that same nice scale feel..<br type="_moz" /> |
RE: Timing the Flap/Elevator mix
You could try adjusting the delay in a P-mix.
Mike. |
Hi Mike,
I'm not sure how to do that. The mix is done as a P-mix anyway because I can't offset in the Flap Con. I tried adjusting the ACC. (?) both up and down and it doesn't seem to do anything. Maybe I'm missing something? Miguel |
ACC should adjust this.
Mie. |
Is it possible to do this using the Flap Control instead of a p-mix?
